Old 09-24-2018, 09:42 AM   #1
Brake Controller
Does anyone know if the E-450 (3011DS) comes prewired for a brake controller. Do I just need to buy the adapter and plug it in under the dash? I'm going to start pulling the Jeep on a trailer when I go rock crawling with my son and will need an electric brake controller for the trailer. I have a Prodigy controller I will move back and fourth from my HD2500 truck.
Thanks.
1FastSS is offline   Reply With Quote
Old 09-24-2018, 09:52 AM   #2
I believe it does. Poke around between the brake pedal and the emergency brake. You could have a receptacle or simply the wires themselves, tucked up around the column somewhere.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 09-24-2018, 09:55 AM   #3
clr
I would think that most F450 would have the TBC wiring behind the dash, this may depend upon how old your truck is. My F350 had an integral TBC, that I changed to a P3 as you are talking about. I did this in my case because I changed to disk brakes on my 5th wheel and the integrated brake controller was not compatible.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-24-2018, 10:24 AM   #4
Thanks.
There is a connector behind the coin holder in the dash above the radio. It is intended for the Ford brake controller, adapters are available or you can splice into the wires. The control wire from the connector ran to the correct location in the 7-pin trailer connector. The coin holder snaps into the dash but is difficult to remove, I bought a replacement after damaging mine in removal. Do a search, there are more descriptive posts about the connector including pictures.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 09-24-2018, 10:59 AM   #5
My E-450 is a 2017 but the 3011DS is registered as a 2018......
Old 09-24-2018, 11:13 AM   #6
https://www.etrailer.com/question-241406.html
Old 09-24-2018, 01:41 PM   #7
Thanks.
Ordered from Amazon......$10
Item # 3034-P
brake control, controller
