Old 04-15-2019, 02:01 PM   #1
Cable for TV location 3051s
I have a 2017 3051s and I'm trying to figure out where all the internal cable TV connections are. I tried doing a search but end up in different forums. I'm starting to have picture issues and want to tighten all connectors. Plus not getting HD. Please don't ask about the antenna booster button. Just concerned with my model motorhome locations.
Worked fine all winter but started acting up the more potholes I hit coming home.
Thanks for any help.
Tomban is offline   Reply With Quote
Old 04-15-2019, 10:08 PM   #2
Usually Confused Member
emm-dee's Avatar
The only places I can think of are at each TV, at the external coax connection left rear side near the main power connector, and in the top cabinet, far left side. You'll need to remove each connection box cover to check the fitting. If the problem is on all the TVs I'd start at the upper cabinet. Remove the cover on the box that has the cable/air button. Don't forget the outside TV. A single loose fitting at any TV at the source/input coax connection can possibly cause the problem at other TVs but that's rare.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 04-16-2019, 05:18 PM   #3
Thanks but
So your saying the cable runs from the outside connector to the panel up on the passenger side where the antenna booster button is at to a distribution box and back out to the three TV's correct?
2017 Forester 3051s
2016 F150 toad
Craig, Cheryl, and Fancy
Old 04-16-2019, 05:52 PM   #4
emm-dee's Avatar
Correct.
Old 04-16-2019, 09:34 PM   #5
The plate with the ant/ able switch is the power injector. It also switches between the OTA antenna input and the park cable input. The coax from the park cable connector on the outside of the coach goes directly to the power injector. The power injector has 2 outputs for TVís the one on the front and 1 of the 3 connections on the rear. The 3 connection on the rear is for the OTA antenna, it provides 12volts to power the amp in the antenna head and passes the OTA signal from the antenna to the 2 TV outputs when the switch in in the OTA mode (led on).
If the reception is good from from the OTA and bad from park cable check the cable from the outside to the power injector.
If it is bad from both then check the connections on the 2 TV outputs. If only the front TV is having issues then it is the connection on the front of the power injector.
If it is the bedroom and outside TV check the TV 2 output on the rear of the power injector.
There is also a splitter between the TV 2 output and the outside and bedroom TVís. I am unsure of itís location. Most likely at the bedroom or outside TV antenna plate.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 04-17-2019, 11:00 AM   #6
Thank you so much
That's perfect, just what I was looking for. Now I have to find a place to hook up to cable and start testing. Might have to go to a campground darn.
2017 Forester 3051s
2016 F150 toad
Old 04-17-2019, 11:25 AM   #7
bubbles's Avatar
When you say cable are you referring to coax cable or are you talking about the cable input for park cable. If just for cable input for park cable, remember that the coax cable within your unit is the same for OTH and park cable input. If OTH is good that should eliminate all the coax cable except the one feed from the park cable input to the booster power panel. This is predicated on all TV's having the issue. Just a thought.
Old 04-17-2019, 02:22 PM   #8
joel ritchie's Avatar
Cable
I have s 3011ds and what I found that try and trace your cables. My cables left the amp and went down to the back of my cabinets were the sink was and then around to the bedroom to the closet at the back and up to my tv. I found at the kitchen drawers a 2 way splitter that was hooked up wrong and killed my tv in the back. I would have great signal one time and bad the next. I will try and send you a drawing on mine .it may help.
Name:	2018_12_18 15-28-41.jpg
ID:	201989   Click image for larger version
Name:	2018_12_18 15-27-44.jpg
joel ritchie is offline   Reply With Quote
Old 04-17-2019, 08:45 PM   #9
West Cactus's Avatar
Joel,
Where did you get the schematics? Would make it easier for me to figure out my set up!
2015 Forester 3051S
West Cactus is online now   Reply With Quote
Old 04-18-2019, 08:25 AM   #10
Cable
i got these from forest river. Do you have a dish .i have others . If you can tell me a little more about what your c has maybe I have the right one for you. If you look on the drawings it is for all class c. Like I said mine is a 3011ds. I donít think there is not that much difference.
305, cable, cat, location
