Old 08-18-2018, 10:55 AM   #1
LinandLen's Avatar
Cable Tv question
We have a 2016 2861 DS. Did a search on this, and canít find it. Anyway, weíre at a resort RV campground, tried to get their cable Tv using cable outside port on coach. Have booster and antenna off, set channel scan to auto like Iíve always done and we got 12 snowy channels. The campground maintenance guy hooked up their tv directly, their signal is good and he got 46 clear channels. We then hooked up directly to our outside tv in the outside kitchen and that worked. So it looks like something is faulty in the wiring in the coach. Ugh, now what?? We can call an electronic guy to come out, but is he going to have to tear my motorhome walls up to find the problem?? Our now $100 a night site is becoming even more costly! Any suggestions as to what to look for? Weíve been to this RV Resort before and hooked up cable Tv just fine. Weíre stumped.
Linda and Lenny
2016 Forester 2861DS
1995 Jamboree 31N (2000)
1979 Tioga 25' bunkbed (first RV in 1992)
LinandLen is offline   Reply With Quote
Old 08-18-2018, 11:01 AM   #2
Denver To Yuma In 90 Days
If you have a SAT dish connection on the outside right next to your cable in, try hooking up to that.
And also if you have a SAT connection on the wall plate right by the TV's...try that as well!
Both new RV's I've purchased in the last 5 1/2 years had both of these connections wired up backwards from the factory.
In otherwords...I found the cable signal coming through the SAT wiring...
JohnD10 is offline   Reply With Quote
Old 08-18-2018, 11:43 AM   #3
LinandLen's Avatar
I donít have a SAT connection on the outside next to the cable. Itís not a situation with mixed up wiring as we have hooked up to Resort cable before without any problems.
Linda and Lenny
Old 08-18-2018, 11:53 AM   #4
Interesting...
One RV resort I used to frequent had a strange cable setup that I could never make work with my new 5'ver.
However, one time I forgot to change my TV from 'antenna' to cable, and guess what...I got the cable channels!
Turn the antenna amp off and try that to see what happens.
Old 08-18-2018, 12:09 PM   #5
Duckogram's Avatar
Originally Posted by JohnD10 View Post
However, one time I forgot to change my TV from 'antenna' to cable, and guess what...I got the cable channels!...
More than once for me
ILB ( | )
Old 08-18-2018, 12:17 PM   #6
LinandLen's Avatar
The antenna and booster are off. No go. I wish it was a simple fix. The only thing I can think of is we had to remove the outlet panel that has the booster, cigarette lighter, and cable connection last month because our power cord fried, and maybe something came loose from that. #scratchinghead
Linda and Lenny
Old 08-18-2018, 12:26 PM   #7
Duckogram's Avatar
And you re-scanned your TV now set on “Cable”?
ILB ( | )
Old 08-18-2018, 12:27 PM   #8
That is probably it.
I had trouble with that in mine, too and it turned out that two wires were touching each other in there.
Old 08-18-2018, 12:38 PM   #9
Try turning the booster back on and try scanning on 'Antenna' instead of cable.
I can't remember how I did mine when that worked...
Old 08-18-2018, 12:39 PM   #10
D W
D W's Avatar
My guess is that you have something gone awry in your T.V. wall plate. Burnt or loose connection?
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator Mods- Reprogrammed 4L80E
2016 Salem 27RKSS (Pacific Northwest Build)
D W is offline   Reply With Quote
cable
