12-13-2015, 11:20 PM
#61
KJ, I saw your question about the water heater bypass on the other forum. Yes, it is under the fridge and all you need to do is remove the 6 screws. I keep a small rechargeable screwdriver in the motor home with the correct bit and can pop the panel and switch the valves pretty fast. I also marked the back of the panel which side went up so I would always be hitting the same drill holes. There are 3 valves that you turn in order to bypass the water heater. One is not easily visible. Turn all 3 the opposite of the way they are now and you will have bypassed the water heater. Now just make sure your water heater electric switch is flipped to off. I also flip the breaker for the W/H off in the electrical panel by the steps as an additional safety measure.
12-14-2015, 11:41 AM
#62
10-4!
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
12-14-2015, 05:43 PM
#63
One other valve is behind that panel also, its the shut off valve for the ice maker, its the little white push/pull valve. If its turned off the ice maker will not work.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
12-14-2015, 05:50 PM
#64
Wow, I have never seen the ice maker cutoff and didn't know it was there. I have always just slid up the arm within the freezer to cut off the ice maker. I will definitely look for it the next time I go to my unit in storage. Thanks. After 2 years I'm still learning stuff.
12-14-2015, 06:02 PM
#65
Hey Rocket , you use the breaker to turn your electric portion of the water heater on/off ? I have just used the switch at the tank .
2014 Forester 3051s
2012 Sonic toad
12-14-2015, 06:03 PM
#66
Good to know! Thanks!
Jason and Karen
2015 Forester 3051S
12-14-2015, 06:07 PM
#67
I use both the breaker and the switch at the tank. It is like a double safety measure for me to ensure I don't turn on the heater without water in it, since I have gotten a little senile. Ha! The breaker for the water heater is the only one I have ever flipped on and off in the breaker box.
12-16-2015, 09:42 PM
#68
Found it but how do you winterize the ice maker? Looks like they ran the ice maker with antifreeze in the lines but how do you then clean it in the spring?
Jason and Karen
2015 Forester 3051S
12-16-2015, 09:44 PM
#69
And this looks proper for the bypass valves to me. Tank drain is open so it must be right. We pressurized the system with the water pump during the PDI and the pump shutoff so I'm assuming no leaks. They must have dumped antifreeze into the fresh tank for winterizing instead of pumping direct from the jugs.
Jason and Karen
2015 Forester 3051S
12-27-2015, 04:07 PM
#70
Originally Posted by Creativepart
Just a warning that you're going to love your new Forester an abnormal amount. And this will lead to wanting to go on extended trips all the time. Plus friends and neighbors will be jealous when they see your RV in the drive getting loaded for yet another new trip.
I know that everyone thinks their RV is the best, but the 3051S is far and away the best floor plan available in this size and price range.
Agree wholeheartedly!!!
12-27-2015, 04:13 PM
#71
Rims
Has anyone replaced factory rims on their Forester/Sunseeker with customized chrome rims? They weren't offered as an option when we ordered ours; however, the Lexington had the option.
12-27-2015, 04:14 PM
#72
I'm sticking with the wheel simulators for now.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
12-27-2015, 04:16 PM
#73
They really look sharp on the Lexington.
12-27-2015, 09:52 PM
#74
I just installed these; They are not chrome but look just like chrome with no rusting, peeling, or polishing. The finish is applied like powder coating. AEX 189 Dually - it is a PVD finish.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
12-27-2015, 10:00 PM
#75
Great looking rims!
12-27-2015, 10:01 PM
#76
X2
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
12-28-2015, 12:32 AM
#77
They look great. What's the cost for the whole set?
12-28-2015, 11:11 AM
#78
They were $185.00 per rim (x 4) plus M & B and the special Dually air valves. Hubs and rear inner rims had to be painted black.
12-28-2015, 12:31 PM
#79
Beautiful! You kept original inner rim then. Does it keep the brakes cooler?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
12-28-2015, 12:38 PM
#80
I think they just keep the coach cooler.
