Old 05-23-2019, 08:10 AM   #1
Can I run Gen while hooked to 30 amp Pedestal?
I am hooked up in Florida and it is time to run the generator for exercise. Do I need to shut down the “park power” to safely exercise the generator?
Thanks. Rch
RHOUSER is offline   Reply With Quote
Old 05-23-2019, 08:22 AM   #2
That's a good question and I don't know the answer. But for piece (or peace?)of mind, I know I would unplug from shore power before cranking up the gen set.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 05-23-2019, 08:23 AM   #3
Flybob's Avatar
Yes you can run the generator. You either have a manual or automatic switch over that will enable only of of the power options to service the RV at a time.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-23-2019, 08:33 AM   #4
llr
It won't hurt anything but it you are trying to place a load on the generator you need to know how your transfer switch works.
My old class A had 2 ACs but would only allow 1 at a time on shore power so if I needed to cool down quick i would run the Gen and both ACs while plugged in so I know my transfer switch gave priority to the Gen, I have no idea if they all do.
You could always start the Gen then turn off the pedestal breaker if you are not sure, then turn it back on before you stop the Gen then no lose of power in the coach
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 05-23-2019, 03:24 PM   #5
bend302's Avatar
My '05 GT automatically defaults to gen. In FL I always started gen then disconnected th breaker at the post. Never an issue.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 05-23-2019, 03:27 PM   #6
rlh1957's Avatar
You probably have a automatic switchover that will go either to Shore power or Gen power, but not both. Even if it is a manual switchover you will only be able to select house power by Gen Set or Shore Power. You can't run half the coach on Gen power and half the coach on pedestal shore power. It won't split it like that.
rlh1957 is offline   Reply With Quote
Old 05-23-2019, 03:39 PM   #7
bubbles's Avatar
Bill
I think you mean it defaults to shore power but genny has priority.
Old 05-23-2019, 05:06 PM   #8
Just so others know, you won't get double the power. You will get power from one or the other, but not both.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
