Old 05-31-2015, 09:58 PM   #1
SandeeAR's Avatar
Cargo Carry Capacity in Forester 3011DS
I've done searches here and Google and can't find the Cargo Carry Capacity in Forester 3011DS. Would someone please be kind enough to look this up in your unit? Thank you
SandeeAR is offline   Reply With Quote
Old 06-01-2015, 11:19 AM   #2
There should be a yellow sticker on the drivers side door jam.
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
torino421 is offline   Reply With Quote
Old 06-01-2015, 11:26 AM   #3
It varies depending on what options you select. But to give you a ballpark idea, Our 2015 sunseeker 3010ds....the twin to the 3011..... Has 1685. That is with the Bigfoot jacks which add some weight. Some will be closer to 2000 pounds but each one may be different.
jrwalkerpa1 is offline   Reply With Quote
Old 06-02-2015, 10:07 AM   #4
SandeeAR's Avatar
Thank you so much. We don't own one yet. Hopefully buying one soon. Trying to compare to the CCC I have now.
Old 06-02-2015, 10:10 AM   #5
SandeeAR's Avatar
jrwalkerpa, what is the difference between a Sunseeker a and a Forester?
Old 06-02-2015, 10:31 AM   #6
Physically they are largely identical and floor plans are the same (i.e. forester 3011 is a Sunseeker 3010, etc). The difference is largely in trim levels. The Forester will have a few higher-end features but many of the things that are standard on the forester are optional on the Sunseeker, although there are usually two or three things that are only available on the forester. Some items are options on both. Sometimes, the colors/patterns/available full body paint, etc available are a little different. Basically if you get a Sunseeker with all of the options, you almost (but not quite) have a Forester!
Old 06-03-2015, 07:33 PM   #7
SandeeAR's Avatar
Thanks so much!
forester
