Old 11-15-2016, 04:21 PM   #11
Sagecoachdriver's Avatar
This morning, I used the touch up paints and covered over all the white showing on the back vertical seams. I had plenty to do, but still lots of touch up left. Will wait a couple of days and then seal with clear silicone caulk. That seems to be what FT used on the lower sections. It's like the guy caulking at the factory didn't want to take the time and get a ladder to do the top 4 feet. Glad I'm getting this done before the rainy season if we have one here in SoCal. Roof looks good, just hope the slide seals work properly.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 8 trips 30 nights
Sagecoachdriver is offline   Reply With Quote
Old 11-15-2016, 04:31 PM   #12
Iwannacamp's Avatar
FWIW they make paintable seam sealer in the body shop world... would it seal the RV stuff I dunno...
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-15-2016, 05:40 PM   #13
I have a recess around most of my windows no caulk. The dealer said they is a rubber or foam type seal/gasket. Have any of you added caulk around yours?
Old 11-15-2016, 06:11 PM   #14
Tinkerer and Putterer
Dicor is paintable and I have been able to get touch up paint from Forest River in the past. I was picky about repainting the dicor after every reseal but once I realized that I was going to have to redo the repaint every 12 to 24 months I decided that a little bit of white showing didn't really bother me. Unfortunately I got my touch up paint last time I was at the factory so I don't have a contact at FR to get the paint. Hopefully one of the kind souls that work at FR will be able to PM you that info. They gave me my paint in 100 ML containers without any applicators. NBD since I knew where to go to get some nice applicators:
https://www.griotsgarage.com/product...e=&from=Search
After you use one of the syringes to apply a line of paint to the area your touching up, one of the DWs foundation makeup triangle sponges will work awesome to cover the larger area. The kit above also has tiny applicators for touching up the edges of the Dicor so you don't accidentally get paint on the roof etc.
After o couple rounds of a few hours on my knees I quickly got over my perfectionism but if you want to go for it, the kit above might keep you from adding to your sailors vocab.
BTW the paint doesn't exist that will move with an elastomeric sealant like Dicor. I don't think tinting it would be a good idea since the tint would never match your paint. Add to that the possibility that the changes caused by the tint might mess up the Dicors sealing properties and the idea of tinting becomes much less appealing IMO.
HappyGuy is offline   Reply With Quote
Old 11-16-2016, 02:03 PM   #15
Our 2012 Lexington has the same issue at the transition from the rear cap to the sidewalls but our unit is painted in mostly darker colors with the rear cap and transition all dark brown. I cleaned up the area and used "Pro Flex RV Sealant" which is available in black. It turned out really well and unless you look really close you don't notice it.
2012 Lexington 265 GTS
clhjsh is offline   Reply With Quote
Old 11-17-2016, 12:30 AM   #16
NMWildcat's Avatar
Might look at Big Stretch colored caulk by Sashco. I used the grey colors on some of my vertical seams and it worked very well. I think I found it at Home Depot. But there are quite a few more colors online.
Scott and Liz - Southern NM
Old 11-17-2016, 03:52 PM   #17
I asked the same question on the forum and at the dealer and have never really gotten a a good answer myself. I had a leak on the one window above the sink and the dealer contacted FR who said to caulk around the top of the window. That seems to have stopped the leak but one has to wonder why this was the fix if the windows are meant to have a gap and not caulked?
newRVer is offline   Reply With Quote
caulk
