Old 10-20-2016, 06:42 AM   #1
Caulking issues
I have a 2016 3011 forester. Any one having caulking issues. It's starting to peel off but the problem is the paint job is coming off because they caulked everything and then painted the unit. Is there a caulk that is brown that matches the brown paint job. Will contact forest river for ideas. Warranty ran up in August. Any ideas would be great.
Kc2427 is offline   Reply With Quote
Old 10-20-2016, 08:35 AM   #2
sgtlm17's Avatar
Yes I have this problem. Caulking or silicone is flexible and paint is not. I notice it most at vertical seems.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 10-20-2016, 12:09 PM   #3
Tombsy's Avatar
+3, I was a little puzzled by it as well. I used some black aquarium sealant on the worst spot on the inside corner of the rear bumper just to seal it up. I've used it for other projects and its pretty tough stuff used for assembling aquariums. You can't really notice the colour when its weathered a bit. I've read that silicone caulk isn't really recommended so we'll see. But I could use a bit of the dark brown touch up paint for a couple other spots if anyone has the codes.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 10-27-2016, 06:39 PM   #4
+4 mine too, but waits until warranty is up. Very Sad.
13larry is offline   Reply With Quote
Old 10-28-2016, 12:10 PM   #5
I'm still under warranty and both verticle seams for the back cap have the paint peeling.
I am still mentally debating with myself if I want to go through the bother and time to have them fix it, or just leave it as is due to it happening again unless they change the caulking.
To the OP, if possible you might want to change the heading to something like paint coming off caulking to catch more eyes.
1992-94 1983 Fleetwood Jamboree Rally class C
1994-99 1995 Holiday Rambler Endevor LE class A
2000-03 2000 Custom Monaco Windsor class A
2003-12 1997 Blue Bird Wanderlodge WB 43 class A
2016-17 2016 Forest River Forester 2801 QSF class C
2017 2018 Renegade Verona 36VSB Super C
AncientMariner is offline   Reply With Quote
Old 10-28-2016, 12:13 PM   #6
sgtlm17's Avatar
I will use Tombsy method in the spring.
2011 Jeep JK Toad
Old 11-06-2016, 07:55 PM   #7
Same problem here. Also, the paint seems thin in several places. Several spots on the gutter on the top have lost paint as well, as the hinges on several compartment doors. There is a number in the driver's door I think for the company that mixed the paint. I had the body shop that did the warranty work mix up touch up paint for the four colors. They have a machine to create an exact match.
AbdRahim is online now   Reply With Quote
Old 11-11-2016, 07:28 AM   #8
We have the same issue here. We are making Forest River aware of this problem and hopefully will be able to get this (along with a few other issues) addressed when we uncover our new 3051 in the spring.
13STL
2017 Forester 3051S
Jill, Mark (and dogs Paco & Isabel)
13STL is offline   Reply With Quote
Old 11-13-2016, 02:25 AM   #9
Sagecoachdriver's Avatar
I have notice white showing on the side verticle seams at the very rear. Since mine has the indigo full body paint, it's been difficult to find a black and grey caulk to match. Mine came with 4 little bottles of touch up paint. I don't think there is enough to cover both sides if I used a white caulk. I'm 3 months out of warranty and winter is almost here.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 11-13-2016, 06:32 PM   #10
Yup. Had this problem from early on. Neither body shop or dealer would not address it. Just said cannot paint over sealant.
Old 11-15-2016, 04:21 PM   #11
This morning, I used the touch up paints and covered over all the white showing on the back vertical seams. I had plenty to do, but still lots of touch up left. Will wait a couple of days and then seal with clear silicone caulk. That seems to be what FT used on the lower sections. It's like the guy caulking at the factory didn't want to take the time and get a ladder to do the top 4 feet. Glad I'm getting this done before the rainy season if we have one here in SoCal. Roof looks good, just hope the slide seals work properly.
Old 11-15-2016, 04:31 PM   #12
Iwannacamp's Avatar
FWIW they make paintable seam sealer in the body shop world... would it seal the RV stuff I dunno...
2017 Puma 297RLSS
Old 11-15-2016, 05:40 PM   #13
I have a recess around most of my windows no caulk. The dealer said they is a rubber or foam type seal/gasket. Have any of you added caulk around yours?
Old 11-15-2016, 06:11 PM   #14
Tinkerer and Putterer
Dicor is paintable and I have been able to get touch up paint from Forest River in the past. I was picky about repainting the dicor after every reseal but once I realized that I was going to have to redo the repaint every 12 to 24 months I decided that a little bit of white showing didn't really bother me. Unfortunately I got my touch up paint last time I was at the factory so I don't have a contact at FR to get the paint. Hopefully one of the kind souls that work at FR will be able to PM you that info. They gave me my paint in 100 ML containers without any applicators. NBD since I knew where to go to get some nice applicators:
https://www.griotsgarage.com/product...e=&from=Search
After you use one of the syringes to apply a line of paint to the area your touching up, one of the DWs foundation makeup triangle sponges will work awesome to cover the larger area. The kit above also has tiny applicators for touching up the edges of the Dicor so you don't accidentally get paint on the roof etc.
After o couple rounds of a few hours on my knees I quickly got over my perfectionism but if you want to go for it, the kit above might keep you from adding to your sailors vocab.
BTW the paint doesn't exist that will move with an elastomeric sealant like Dicor. I don't think tinting it would be a good idea since the tint would never match your paint. Add to that the possibility that the changes caused by the tint might mess up the Dicors sealing properties and the idea of tinting becomes much less appealing IMO.
HappyGuy is offline   Reply With Quote
Old 11-16-2016, 02:03 PM   #15
Our 2012 Lexington has the same issue at the transition from the rear cap to the sidewalls but our unit is painted in mostly darker colors with the rear cap and transition all dark brown. I cleaned up the area and used "Pro Flex RV Sealant" which is available in black. It turned out really well and unless you look really close you don't notice it.
2013 Itasca Ellipse 42QD
-2012 Lexington 265 GTS- Sold
Tow Vehicle 2017 GMC Acadia
clhjsh is offline   Reply With Quote
Old 11-17-2016, 12:30 AM   #16
NMWildcat's Avatar
Might look at Big Stretch colored caulk by Sashco. I used the grey colors on some of my vertical seams and it worked very well. I think I found it at Home Depot. But there are quite a few more colors online.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 11-17-2016, 03:52 PM   #17
I asked the same question on the forum and at the dealer and have never really gotten a a good answer myself. I had a leak on the one window above the sink and the dealer contacted FR who said to caulk around the top of the window. That seems to have stopped the leak but one has to wonder why this was the fix if the windows are meant to have a gap and not caulked?
newRVer is offline   Reply With Quote
caulk
