Old 06-26-2018, 06:46 PM   #1
changed tank sensors now other things don't work
I have a 2018 3011DS. The tank sensors for the grey and black tanks were not working correctly so they replaced them. Well the sensors seem to work fine now, but the bathroom light and the bedroom lippert panel does not work. How are these things connected. Any help is appreciated. We did check the lippert panel with the working one in the living area and it would not work in the bedroom either.
lacrawgator is offline   Reply With Quote
Old 06-27-2018, 02:51 AM   #2
Kirk S's Avatar
Hopefully a wire wasn't cut or disconnected during the sensor replacement. Check your 12 volt fuses first. If all are good the next place would check is the compartment where the Lippert modules reside to see if a there may be a loose wire. My tank, lighting and generator modules are behind a panel beside the stairwell.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 06-27-2018, 01:41 PM   #3
Thanks for your suggestion, it was a fuse.
tank
