Old 10-21-2014, 01:57 AM   #1
West Cactus's Avatar
Checklist when home
With grey and black water dumped at last overnight, what should be done to prepare the MH when parked for a few weeks or up to a month? I dumped the fresh water but I am sure more should be done to store it.
West Cactus is offline   Reply With Quote
Old 10-21-2014, 03:09 AM   #2
Just a member
kandl's Avatar
Originally Posted by West Cactus View Post
...what should be done to prepare the MH when parked for a few weeks or up to a month?
I would drain the hot water heater and open up any low point drains. That's assuming you won't be expecting any freezing temperatures like many of us in the more northern latitudes.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 10-21-2014, 04:14 PM   #3
Turn battery disconnect off or parasitic loads will drain the house batteries.
I also turn propane off just in case a valve does not turn off bubble tight. Also propane regulators have been known to fail.
Turn off water heater electric if you drain it just in case you forget to refill it before you plug in or start the generator.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 10-22-2014, 09:03 AM   #4
Turn off the battery disconnect switch and propane.
I wouldn't worry about draining the water systems. However if the last place you camped had poor quality water, you may want to drain or flush it out.
The other thing I always do when home is put both chassis and coach batteries on battery tenders.
ATVer is offline   Reply With Quote
check list
