Old 01-19-2016, 11:53 AM   #11
Run the generator under load
We also purchased in the winter. The only issue we found was when running the generator, turning on the A/C shut it down. Fixed now but was a PITA with the dealer.
Karter is offline   Reply With Quote
Old 01-19-2016, 12:21 PM   #12
We have been through ALL of this in the WINTER! Super Cold but Clear roads! Dealership was Small so NO inside pre Heat! We were able to Test the H and Cold system with 50 PSI Air,No leaks! Come Spring the FW tank leaked and filled the Belly Cover,bad tank,and after replacing the Tank and tank heater the Water pump was Junk as well,2 things that could NOT be Tested with Air! Go for the COMPLETE PDI! Youroo!!
Old 01-19-2016, 05:53 PM   #13
17Racer's Avatar
and if you wish, you could watch the "Winterize Job" and take notes.
2014 Forester 2301 - Chevy
17Racer is offline   Reply With Quote
Old 01-20-2016, 06:40 AM   #14
Good point! I will include that as the final part part of my new plan!
newRVer is offline   Reply With Quote
Old 04-04-2016, 02:59 PM   #15
Originally Posted by newRVer View Post
So far that has been a lot of good feedback. I am now leaning towards having the unit de-winterized and run through normal activity during our walk through. I want to absolutely make sure that that there are no leaks, hot water heater works on gas/electric, heat works on heat pump and furnace and hopefully also be able to test out the AC, among other things.
RVr
FYI
I did have the RV dealer un-winterize the unit and fill it with water even after they informed that it was not necessary. In the end, I found a big leak under the sink which required changing out the faucet and the ice maker in the frig was not working. In the next week or two I will be taking it back to check out the ice maker and look at a few other minor things.
RVr
pdi
