07-26-2017, 06:17 AM
Retired and Loving Life!
Condensation on bathroom ceiling.
I am camping at Myrtle Beach this week, and am constantly wiping condensation off of the ceiling in the bathroom. It forms along the a/c vent line, and can become quite heavy at times. The Bathroom stays a bit warmer than the other rooms, I believe due to the skylight over the shower area, so I have been leaving the door open, but the condensation still collects. Has anyone else experienced this in high humidity areas? What are your suggestions, other than wiping it off constantly? Thanks.
07-26-2017, 06:52 AM
"On the road again"
If you have a vent fan it's recommended to always have that open and running during showers or other use that might cause a lot of moisture to be present. In hot/humid areas sometimes all you can do is wipe and wipe some more.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
07-26-2017, 07:04 AM
Like first post, you're dealing with high humidity and the cool air in the AC ductwork causing condensation. Wipe, wipe, and wipe some more.
07-26-2017, 08:49 AM
Consider replacing the skylight with a MAXX-Fan with remote if the skylight is the typical 14"x14".
07-26-2017, 12:29 PM
This is typical in high. Humidity and running ac its the cold air from ac. If you touch where the condensation is you will feel its very cold from the AC air passing g by it. As said previously wipe wipe wipe.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
07-26-2017, 12:38 PM
possibly put small fan in the area pointing up to circulate air in/out of that area
2014 Shamrock 183
07-26-2017, 01:12 PM
Is there any way you can add more insulation between the ceiling and the AC ductwork? Something as simple as a 1" thick piece of semi-rigid fiberglass insulation might slide in under the duct (probably flex) and the ceiling, and this would isolate the duct from the ceiling and eliminate the cold spot on the ceiling that precipitates condensation.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
07-26-2017, 02:17 PM
X2. The roof vent fan is not circulating enough air to dissipate the condensation. A fan on the shower floor directed straight up would most likely evaporate the condensation.
If you have a vent open in the bath area without the ceiling fan running, it is possible that the hot moist air is entering via the vent and condensing on the ceiling. That hot/moist air would hold to the ceiling and condense.
07-26-2017, 03:29 PM
In mine the duct is cut into the insulation. No room to slide any extra in!
07-26-2017, 06:31 PM
We had the same problem while we were there a couple of weeks ago. The throw rug we keep in there got pretty damp. Due to the humidity and the fact that my DW and 3 granddaughters prefer 65 degree temps sort of caused the problem. When am I going to learn that $100 sites And $50 golf carts are not going to compete with cool temps and cell phones
07-27-2017, 09:13 AM
Cover the Skylight,,, and run the Vent Fan ???
I covered our Skylights with 4 or 5 layers of White paint !!!
LOL !!!
07-27-2017, 12:43 PM
I keep the bathroom a/c vent almost completely closed and it still stays comfortable.
We haven't experienced any ceiling condensation in our 3051.
We keep the temp in the mid to low 70's and a 50 - 60% humidity reading. Anything above 60% humidity feels sticky.
Kirk
2017 Forester 3051S
07-29-2017, 04:53 AM
What are you using to read your humidity levels?
07-29-2017, 05:47 AM
An RV is the last place I would shower,,, I use the Campground Grounds Bath Houses !!!
More water,,, more room & they get to deal with humidity & the cleaning !!!
07-29-2017, 10:33 AM
Same brand as the fridge & freezer temp sensor I bought.
Most likely from Amazon.
Kirk
2017 Forester 3051S
07-29-2017, 05:03 PM
Attachment 146453
That's smart! And you use a dehumidifier too?
07-29-2017, 07:27 PM
No separate humidifier.
That's the air conditioners job if it can keep up.
Kirk
2017 Forester 3051S
