Old 07-12-2015, 12:08 PM   #11
Originally Posted by Wandering View Post
Kinda goofy but seems like mine work if I have the TV in AV mode the put the disc in. Switching TV to AV mode after disc starts and nothing comes thru! Rainy weekend camping help me find that one.
That's really interesting. Mine seems to work after no problem. My biggest gripe are the horizontal lines that run across the screen on the rear TV . In my opinion this because the video cable is poor quality.
steverkemp is offline   Reply With Quote
Old 07-12-2015, 01:49 PM   #12
benagi's Avatar
Steve, when running a dvd in the indash dvd player, what TV's can you view that on? Haven't played with that part of our system yet.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-12-2015, 05:03 PM   #13
Just the main tv over the dinette
Old 07-12-2015, 05:11 PM   #14
benagi's Avatar
Just tried it out, worked first time. Now I just need to be able to get to the earphone jack in the bedroom. Impossible without removing the TV which is hard mounted to the cabinet, so I'm going to add a metal mounting bracket back there so we can remove the TV from the bracket like the bunk room TV does now.
1968 tent trailer
1985 Jamboree 23 ft
Old 07-12-2015, 05:24 PM   #15
Creativepart's Avatar
Actually it's not the quality of the cable-it's just that RF/coax is the very lowest quality signal. AV, component, S Video, and HDMI are all higher resolution (I listed them in order of signal quality).
My Satellite Receiver puts out a beautiful image with HDMI but RF signal via coax looks terrible on a higher resolution flat screen TV.
I've been researching "HDMI over Coax" as a way to get a better signal into the bedroom TV. Or maybe even sending a HDMI signal via wireless adapter. Both are available.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 07-12-2015, 06:39 PM   #16
2012 Solera
Horizontal lines
Solved this, and an audio hum issue, on our 2012 Solera "S" with ground loop isolators on both stereo lines and on the video coax. See my post (#8) on this older thread: Noise/Hum through Surround Sound system.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 07-12-2015, 08:45 PM   #17
Thank you so much!!!!
Old 07-12-2015, 09:04 PM   #18
Would this work instead? http://www.amazon.com/gp/aw/d/B004LG...J5TGZHP3TMPF89
Old 07-12-2015, 09:04 PM   #19
2012 Solera
For more detail on the ground loop isolators, see my post #83 on this thread: Mods & Purchases - fun thread
Note the Stinger isolators on Amazon look to be many times more expensive now than they were when I did this mod - I would use something else today!
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-13-2015, 12:31 AM   #20
benagi's Avatar
Problem is, you can't get any size hand behind the TV where the earphone jack is. Need to be able to get behind the TV using a swing bracket or a fixed one you can lift the TV off of like the bunk TV. No other way to get to that jack. What's nice about using the earphone jack is, once plugged in it cuts out the TV speakers so as not to disturb anyone else.
1968 tent trailer
1985 Jamboree 23 ft
dvd
