Old 09-06-2015, 10:12 PM   #21
Creativepart's Avatar
Originally Posted by Sagecoachdriver View Post
Had the refrigerator running for the past 3 days and the temperature doesn't seem to get below 43 degrees. I did see the thermistor on the fins and the label saying colder. I moved it up to the coldest with not much change.
My Winnebago's Norcold would freeze the water bottles and the overnight temperature could drop to 28 in the fridge. Usually set it down from 5 to 3
On our RV the fridge has to be level - the minute we lift the level jacks in our driveway the fridge starts getting warmer. But parked level and driving we see 35 to 37 when set to close to the coldest settings.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 09-06-2015, 10:29 PM   #22
Sagecoachdriver's Avatar
I'm going to miss my Norcold. We didn't have levelers and I was always off some. As long as I had the bubble touching the circle it ran great. Never a problem except freezing my jug of lemonade in the fridge.
I have it level and the temp is 42.
Freezer is -2
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-06-2015, 10:31 PM   #23
Our Norcord in the Arctic Fox didn't care about level at all. The Fridge was always cold-level or not.
Old 09-06-2015, 11:12 PM   #24
I just put in 2 fridge fans along with more food . Let's see what it says in the morning. not exactly perfect level wise about 2/3 in the circle.. I have a good drop in my driveway and if I use the levelers, I will be off the ground. Used my drive-on yellow levelers for now.
Creativeparts, what mpg are you getting without the toad? I can live with 8-9.
And what tire pressure and air bag psi?
Thanks, Happy Labor Day!
Old 09-06-2015, 11:18 PM   #25
Bluepill's Avatar
Thanks for the quick replies.
Probably going to install the adjustable thermostat in the water heater. Getting 145 degrees currently. I was getting 155 degrees in the Winnebago. Replace it with the adjustable and got it down to 117 degrees. It's just the DW and I and we've never run out of hot water with that lower temperature.
Just a thought on the thermostat change. You might want to try this first:
On my old motorhome I always left the water heater off until I was ready to use it. It was a combo LP and 120 Volt electric. When I first got up in the AM, I would turn BOTH heat sources on, and we had good hot water within 10 minutes. After we both showered, I would turn the heater off and there was sufficient hot water left for dishwashing.
2008 Itasca Meridian 37H
Old 09-07-2015, 08:26 AM   #26
Sagecoachdriver - I'm getting 7 mpg with the toad and pretty much the same without the toad. I'm expecting 7 mpg and hoping to see some 8's on the expressway.
It is what it is.
Your 2701DS is 4' shorter and 1,400 lbs lighter than our 3051S... so 8 mpg would be a reasonable expectation.
I have 80 psi in the rear tires and 75 psi in the front. Air bags are set to 79 psi right now. I may fool around with that some. I took one short trip with the airbags at 10 psi and another with it at 79 psi. The vehicle handled better at 79, but the ride was noticeably rougher (obviously).
Old 09-07-2015, 10:47 AM   #27
Creativepart- my fridge is down to 38 this morning. I guess the 2 fans helped a bit.
My Winnebago is 6 feet shorter and 2200 lighter than the Forester. The mpg was 9.5 to 10.5 until they changed the formula back around 05. Currently, I am getting around 9 and that's running at 70mph. The new one will be running slower at 60-65 in the slow lane with the truck. I never really kept track on the cost and don't want to start now.
Finishing loading today for the maiden voyage tomorrow up the California coast for 3 nights. Hope I can start relaxing now and enjoying it.
Old 09-08-2015, 10:21 PM   #28
We are on the first night of a 3,000 mile one-month trip from Texas to Washington DC and back. So our shakedowns are officially over. We travel between 60 and 65 mph.
Old 09-08-2015, 11:58 PM   #29
Day 9 Shakedown trip!!!
We are on our shakedown trip. Mpg was 7.5 for over half the trip with gusty winds. Then rose to 7.9 by the time we filled up at about 200 miles calm. That's per my scan gauge.
Did handle well in the wind.
I did notice on my scan gauge that the TFT transmission temperature runs hotter than my 2003 Ford E-350 with the 4R100. 180-200 Winnebago and 204-212 for the 5R110 in my Forester.
The refridgerator is 0 in the freezer and 39-41in the fridge. Not at all like my Norcold.
We backed into our campsite and I began to setup the Bigfoot levelers. I first put down 3 one inch lego type squares under the rear leveler feet. Per the instructions in the manual and by my salesman at PDI, I turn on POWER and red light came on. I then waited a few seconds then pushed the START button and the levelers extended. The fronts were fine per my level and only the rears needed to be extended. They automatically extended and raised up the front and reARS a lot. I pushed the Retract button and then the two front buttons. They retracted all the way up. I was still over extended on the rears, so I tried to retract them a little and they were bouncing. My DW said there was fluid on the passenger side read leveler foot plate. We still were not level but I then paniced and pushed the RETRACT all button and they all retracted. I called the dealer and they said it could be a few things. I opted not to use it until they see what's going on. I recall reading that some say they don't use the START button as it causes them to over extend and causes problems. I can see it lifting all the wheels off the ground, luckily not this time. The dealer's tech said I should have used more lego blocks almost up to the foot to shorten the throw. Will do that next time.
Old 09-09-2015, 07:36 AM   #30
Your unit must have different levelers. On mine you push the on button. Then wait for the leveler to boot up. Then all you do is push the Auto button and stand back. Done.
forester
