Old 08-31-2015, 02:29 PM   #1
Disengaging slide motors
I haven't had any problem with the slide on my 3051S but I don't know how to disengage the slide motors in case i do. the instructions say look under a warning sticker, but I'm still not finding it.
Thanks as always!
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 08-31-2015, 11:02 PM   #2
Creativepart's Avatar
Watching this thread... I need to know as well. Someone said the motor is under the drawer were the oven would be. But I don't know if that's where you'd disengage the slide motors.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 09-01-2015, 08:15 AM   #3
Class C Representative
Joshua Cavitt's Avatar
You need to pull back the rubber seals from the interior, find the set screws, take those out and the motors will be disengaged for manual use.
Joshua Cavitt is offline   Reply With Quote
Old 09-01-2015, 09:02 AM   #4
BooBoo23's Avatar
You can download a manual for the slide operation and troubleshooting by going to www.forestriverinc.com/index.aspx Select Motorhomes, then go to "Tools" and scroll down to online manuals. Select Class C motorhomes, and then find "leveling jacks and slide room operation", then "slide room operation". When you get to that page look on the right side and there will be a list of PDF's to find the proper slide system. Good photos and descriptions.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is online now   Reply With Quote
slide
