Old 08-29-2016, 11:39 AM   #11
Wolverine 1945's Avatar
I just though air leaks were a normal thing ???
Ours have always lost about 30 lbs on a 3 or 4 day trip,,, driving approximant 500 to 600 miles !!! I started carrying a small compressor,,, so I could pump them up !!!
GREAT,,, now I have to crawl my fat ass under the Sunseeker & check for leaks !!!
LOL !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-29-2016, 03:15 PM   #12
LOL !!!
Best way to check for air leaks is to use a spray bottle or small brush with water/dish soap mix. I would check the air filler valves first. Sometimes they stick and leak very slowly. I was told by a tire man that the valve caps are also important because they seal the valve stem. Spraying the soap mix on a valve or fitting will make the leak bubble.
Another consideration is to check for a line or fitting that is stressed. It may only leak when it is getting jostled.
PenJoe is offline   Reply With Quote
Old 08-30-2016, 08:41 AM   #13
Valve stems are easy to check,,, just need a little spit !!!
LMAO !!!
air bags
