Old 03-11-2016, 10:29 AM   #1
Sagecoachdriver's Avatar
Does hookup water pass thru house water filter?
Met a fellow FR Class C owner the other day in Death Valley and he commented on hookup water having a lot of chlorine smell. I said I thought the hookup water also passed thru our factory installed water filter. He said he didn't think so.
I had put an inline cheap CW water filter at the hookup without thinking like I did when using hook up water in my old Minnie Winnie. We had no chlorine taste or smell. When we left, I gave him my filter as he was staying another 4-5 days and had family arriving.
So, does the hookup water go thru the in house water filter or not? How about the water heater?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 03-11-2016, 10:46 AM   #2
City water and F/W tank Pumped water goes through your Factory Installed Filter System! Youroo!!
youroo is online now   Reply With Quote
Old 03-11-2016, 11:29 AM   #3
sgtlm17's Avatar
All water regardless of source go through my house filter.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 03-12-2016, 06:45 PM   #4
If I sanitize the FW tank and over chlorinate it, will running the faucets also sanitize the lines or will the Pur filter remove all the chlorine? Because I have drained my tank and refilled it. The remaining water in the tank was enough to give me a high chlorine level from the faucets. I drained the tank again and got the chlorine level down to an acceptable level.
Old 03-12-2016, 06:59 PM   #5
sgtlm17's Avatar
I don't know how much chlorine that filter can handle. Sanitizing is a lot of chlorine to remove via filter. I would sanitize without filter then drain and refill and rinse before I put filter back in
Old 03-12-2016, 07:08 PM   #6
Ford Idaho's Avatar
X2
I would install a new filter.
Old 03-13-2016, 01:23 PM   #7
Some house filters are plumbed with a bypass, so if yours has one, make sure your filer isn't being bypassed. But as others have said, both city and f/w tank water goes through the filter.
DrLewie is offline   Reply With Quote
Old 04-12-2016, 07:51 PM   #8
Best to trace your piping. On my unit the city water did not pass thru the filter. Per the piping diagrams it was supposed flow thru the filter but sometimes the factory personnel take shortcuts and connect things differently. Factory warranty rep called it an "oversight". Replumbed it myself. At the time I checked other units I saw at shows and found most to be okay but there were some that were bypassed.
ATVer is offline   Reply With Quote
Old 04-12-2016, 08:01 PM   #9
Berkshire 390QS
NO3putt's Avatar
Easy way to check, take filter off, run pump on for a few seconds, if water comes out where the filter is, then it's going thru the filter. (providing your not connected to city water)
Old 04-13-2016, 11:13 AM   #10
That won't work because the water will just backflow from the filter outlet side if it was plumbed incorrectly.Never saw one where the onboard pump flow was bypassed. It was always city water flow.
water, water filter
