Old 11-02-2015, 11:22 AM   #11
For the thermostat manual Google "Single Zone LCD Thermostat Operating Instructions". You will see there is an adjustment for temperature differential for the A/C Heat Pump unit. There is only two settings available - a 1 degree or a 2 degree differential. Your unit is at a 2 degree differential as that is the factory preset setting. You would probably be happier with a 1 degree differential. I am guessing that would make your heat stay on for a shorter period of time but cycle more frequently. Please anyone, chime in if this is incorrect.
Rocket City Gary is offline   Reply With Quote
Old 11-05-2015, 09:45 PM   #12
MNtraveler's Avatar
Dometic air conditioner and heat pump 2016 3051s, what model?
Found it - very helpful - thanks! There are times when the 1 degree differential would be better but others where 2 would be best to avoid excessive cycling of the system.
The heat pump running in high fan seems to be controlled by the auto setting - if differential is 5+ then it runs in high, if 4 or less it runs on low. This appears to be common across the heat and A/C options too. (Could run low vs auto but then it would run constantly whether heating or not.)
Interesting to learn that the heat pump has a coil defrost cycle every 25 minutes when the outside temp is 42 or less. During the time the heat goes outside and cold air is blown inside. Not ideal at all so not most useful in this range. Also it won't run (heat) at all below 30 degrees. Best to use the furnace (also the heat pump does not feed the ducted air lines so does not circulate well).
Thanks again!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-06-2015, 07:20 PM   #13
The thermostat on our year model 2011 Sunseeker automatically switches from heat pump to furnace below 30 F if the heat pump is selected. I don't know if the newer thermostats do that, so you may want to check yours. Also, I'm pretty sure the fan does not run when the heat pump is in defrost mode. Again, the new thermostat may work differently.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 11-06-2015, 08:04 PM   #14
Boso's Avatar
Didn't understand the ducted airline instruction but mine does blow thru ducts in ceiling at all vent openings in ceiling but when it's cold outside I close the bedroom vent because the air is cold but warmer than outside temp so it does heat the Rv when cold but not when it's freezing
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-06-2015, 11:55 PM   #15
MNtraveler's Avatar
"Feel cold air" - doesn't exactly say cold air will be blowing out. But I think we felt that pretty cold wind.
Name:	ImageUploadedByForest River Forums1446875693.497114.jpg
2016 Forester 2401R
305, air conditioner, dometic, pump, modifications
