Old 11-23-2014, 08:31 AM   #11
Witch Doctor's Avatar
Originally Posted by lmouhot View Post
Donniedu ice full bail is down. Does anyone know where the water supply valve is located? I am defrosting the whole unit now.
Scizzorman
Read post #7
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-23-2014, 08:48 AM   #12
bubbles's Avatar
I think the OP is asking for the location of the solenoid valve that controls the water flow to the ice maker. I have a MH and the valve on mine is through the access panel on the outside of my MH (back side of the fridge). It is a blue solenoid valve in series with the shut off valve.
Old 11-23-2014, 10:28 PM   #13
Ice maker dumping ice again. Defrosted fridge and filled water tray by hand, rand full cycle test on gears.cant tell you what might have been wrong but has dumped ice twice in the past 4 hours .
Scizzorman
lmouhot is offline   Reply With Quote
Old 11-23-2014, 10:33 PM   #14
Sorry what do you mean by "ran full cycle test on gears"?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 11-24-2014, 02:29 AM   #15
Scizzorman
Glad to hear your back in business again. Sounds like your water supply tube froze up.....
Old 11-24-2014, 05:49 AM   #16
Jfrauts there is a small gear next to large gear on ice maker that you can use a flat screwdriver turning counter clockwise to take the motor thru a full cycleas described in manuel.
dometic
