Old 09-03-2018, 08:54 AM   #1
Campincarters's Avatar
Door whistle
Does anyone have any recommendations for reducing air around the coach door when traveling.
Campincarters is offline   Reply With Quote
Old 09-03-2018, 09:39 AM   #2
Duckogram's Avatar
A foam gasket should eliminate air leaks.
ILB ( | )
Old 09-03-2018, 10:09 AM   #3
rsdata's Avatar
foam gasket can be found at HD in many width and depth with a sticky side that allows you to easily add it to the inner side of your door frame... You can try this for not a lot of money
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 09-03-2018, 03:27 PM   #4
Thanks. It is there already but I can replace it.
Old 09-06-2018, 01:16 AM   #5
I have noticed with ours that if I wipe the seal down with spray silicone like Armor All it greatly reduces the wind noise. Assuming it helps it seal better.
Azzy1016 is offline   Reply With Quote
door, forester
