Originally Posted by youroo
The Atwood has a 1/2" pipe thread drain plastic plug,the Suburban has a 3/4" Pipe thread Steel plug/with A Rod! When/if you add/use/convert either one of these Plugs into a Valve draining system you have just created a "White Crud Buidup Dam"! The more "Adapters" you use the Smaller your Drain opening will be,and More "White Crud"! Your choice! Youroo!!
On my old TT, I had the Atwood heater and put in the reducer with petcock. Once per year however I used a "nozzle" I made from a female hose fitting, down to a 1/4" nylon tube. Pulled the petcock with adapter, hooked nozzle to hose, inserted tube into heater, and turned on water full tilt. The "white crud" flowed freely out of the heater around the nylon tube. Along with the "black crud" too
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
