Old 08-05-2014, 12:21 PM   #1
Draining water from main tank
Since I am a newbie with my 2004 Forester 255, I will probably be asking many questions. This one concerns draining the water tank. I looked underneath and found 2 hoses with white caps. Is this where I drain the tank? If so, do I open both? Why are there 2? My other motorhomes only had one drain plug.
Nhisday is offline   Reply With Quote
Old 08-05-2014, 12:37 PM   #2
Drains
Those are hot and cold low water drains, used when winterizing. Keep looking for your fresh water tank drain, mine is a petcock beside the frame near the back but could be anywhere.
leland1950 is offline   Reply With Quote
Old 08-05-2014, 12:42 PM   #3
RSchleder's Avatar
I'm thinking you found the "low water" drains that drain the water out of the hot & cold water lines. There should be a valve under the unit with a handle that when in the vertical position (up or down depending on your unit), drains the fresh water tank. It's there, you'll just have to take a look on your hands and knees to find it.
Good luck!
RSchleder is offline   Reply With Quote
Old 08-05-2014, 02:08 PM   #4
Mine is behind a panel in a rear storage compartment next to the water pump.
campingtom is offline   Reply With Quote
drain, tank, water
