Old 11-27-2015, 01:21 PM   #11
Sagecoachdriver's Avatar
Hijacking my topic?
Going off on 5th wheel wireless cameras! What does this have to do with my specific topic under "Forester" driver's side camera wiring ? Please start your own topic under the appropriate forum. Thank you.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 11-27-2015, 02:11 PM   #12
Sorry, did not mean to hyjack the thead, but it dose have to do with cameras.
When you got your new camera, is it the same frequency, as the old one? All three of mine are on different frequencies.
Ditchdigger is offline   Reply With Quote
Old 11-27-2015, 03:45 PM   #13
Ditch digger, mine is cable not wireless, therefore no frequency. Forest River Factory option and installed.
Old 11-27-2015, 11:39 PM   #14
Boso, what kind of problems are you having with your camera system??
PenJoe mentioned the propriety of the RVS cameras and because FR used ASA cameras, the cables look the same but the wiring is incompatible giving me the "NO SIGNAL". That's going to solve my problem with either the correct cable or splicing.
I called RVS today and they did not have the wire extension cable's wiring configuration. Just a color code and diagram of the pin configuration at the multiplexer's connection. At the multiplexer it's 5 pins and at the camera's pigtail is 4 very small thin wires in a sleeve . Can't get a reading with my multimeter to see what's what. Got the part number off the passenger camera at the multiplexer and will ask the dealer to order one of those as I know it works.
Old 11-28-2015, 10:34 AM   #15
Boso's Avatar
Sage my cameras fog or go blurry anytime moisture is in the air don't clear up until it's not within a few days after ongoing since day one of the first rain still being warranted since its on goingClick image for larger version
Name:	ImageUploadedByForest River Forums1448728463.292108.jpg
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-28-2015, 10:44 AM   #16
Boso, did they replace your cameras? Are the cameras from ASA and the system from RVS?
Old 11-28-2015, 10:56 AM   #17
Boso's Avatar
Yes to system replacement,cameras was thru Velvac but you are probably right on that to.Velvac distributes already attached to mirrors to FR I talked to service Wednesday they have replaced cameras and I also had replaced cameras and I'm sure they work perfect now until it's driven in moisture it will be ok.constant circle it seems
Old 11-28-2015, 11:23 AM   #18
Sagecoach and Boso , Like you guys I am also having problem with left( drivers side ) mirror camera , I don't get a no signal issue, I get the moisture in the camera like Boso, but it does seem " FUNNY" that it is always the left camera people are complaining about. Hopefully someone gets a answer to these problems.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 11-28-2015, 12:04 PM   #19
Moisture?
Here is a photo and the manual for the ASA electronics camera. Besides having the dealer replace the camera, you might try at your own risk, removing the camera and placing it in a zip bag of rice and lay it out in the sun. This may remove the moisture that has seeped into it. Then retighten the 4 screws. If out of warranty, put some caulk around the seam and reinstall. It's just a thought. Learned that rice trick from having my DW wash her cellphone a few times. Good luck!
Caution! don't break the seal on top voiding the warranty!
Another note: You may be able to unmount the camera and attach a bag of rice while still on the arm. Otherwise, if you detach the cable, attach a string on the cable and pull it thru the arm along with the cable. This will make reattaching the cable much easier and no fishing for the cable.
ID:	95180   Click image for larger version
Old 11-28-2015, 01:16 PM   #20
Boso's Avatar
It is not only my left but all my cameras do that but the backup is not as bad Click image for larger version
Name:	ImageUploadedByForest River Forums1448738043.711743.jpg
ID:	95186 I don't think it's the cameras but something else I guess it stays under warranty until it is fixed
