Old 11-28-2015, 01:30 PM   #21
Camera Moisture
Is it possible that the moisture is on the external portion of the lens? Air turbulence may be getting moisture on the lens even though it it is facing rearward.
Here is a suggestion: I spoke to my neighbor whom was polishing his truck and asked what he was using. "ReJex" was the reply. He went on to say that he uses this on his truck glass, boat windshield (plastic) and his fiberglass boat (used on salt water) as-well. I tried it and it does a phenomenal job of sheeting water off both glass and plastic windshields. A coating of this on the camera lenses may solve your problem. Besides sheeting off, it does not fog, does not leave a visible film, and does not damage the surface of the application. It is not cheap, but it may be worth a try.A little goes a long way.
http://www.amazon.com/Corrosion-X-61...ive+car+polish
PenJoe is offline   Reply With Quote
Old 11-28-2015, 01:43 PM   #22
Boso's Avatar
No I don't think so you can dry and no change have tried wax pure silicone spray then polish nothing seems to work but time it always get worse if a constant rain have had to clear after a few days and then re fog as I drove with no rain then clear up after 4-5 hrs of driving
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-28-2015, 01:45 PM   #23
Boso's Avatar
My thought until the first cameras were replaced was moisture entering the lens itself but not after the same problem on second set of cameras
Old 12-01-2015, 08:47 PM   #24
Sagecoachdriver's Avatar
Thanks Penjoe!
PenJoe, you were right, the cable was the problem with the incompatible wiring. Retested it today with the old cable and it works. There are actually two cables connected together and the dealer received one very long one from FR.
Not sure if the dealer is getting a new set or installing the old ones with the splices.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 12-02-2015, 07:35 AM   #25
Happy it worked out for you.
