Old 09-30-2015, 07:00 PM   #21
Sagecoachdriver's Avatar
I bent mine. Works now with no bend in the extension or pressure of the wire on the simulator. Good job!
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-30-2015, 07:31 PM   #22
benagi's Avatar
Sage, I was thinking about putting them on the simulator also, but thought they may scratch them. What do you think?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 09-30-2015, 07:38 PM   #23
Ben, I took another look at your photo. I bent mine the other way as there wasn't enough spring your way. Have you tried it? I wouldn't mount it to the simulator as I don't think there is enough clearance. They may have videos at Pacific Dually.com about mounting these.
Mine are fine now, tight and extended with no bend or hitting the simulator.
Old 09-30-2015, 07:42 PM   #24
Night Stone's Avatar
Originally Posted by benagi View Post
Sage, just finished putting my extensions on. I think the problem in the first place was the air-flex extensions weren't tightened down far enough, so that's why needle valve inside was to low. Also, see my picture below of my modified spring that hold my new extensions. I just used needle nose pliers and reshaped them so they would fit a little better. Doesn't interfere with the simulator at all now. These new extensions from Pacific Dualie are a lot better that the air-flex. Glad I changed them anyway.
Awesome idea, I think I will do that to mine as well, was hard to find any brackets that allows for aftermarket aluminum rims
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 09-30-2015, 07:51 PM   #25
phat phrog stunt crew
Have you ever heard of cats eyes tire pressure monitoring system? Easy to check tire pressure, and only one fill valve to add air at. They work great and ends the argument one generally has with the inside tire valve.
Sent from ny nook using fairly accurate digits.
dwaynerz is offline   Reply With Quote
Old 09-30-2015, 08:08 PM   #26
Are you referring to those extenders for dullies which are like equalizers? Fill both tires at same time? Unless they make it airless extenders than it will work. But other than that, if you get one tire leaking air, basically the other goes flat too.
FRF and FROG member
This Space for Rent
Old 10-01-2015, 07:55 AM   #27
Citrus County, Fl.
GL1800Rider's Avatar
GL1800Rider, sorry I didn't get back to you sooner. I have been looking for my receipt/order. I bought the 18100 which is 7" and designed for the 16" with 4" oval holes in the rim. I believe the 18101 is for the E-350 and has the spring stabilizers for the 2" ovals. Not sure about the length. The Pacific Dualy site wanted $30 for them, I got them at Amazon for around $22 both are plus shipping.
I will look in to getting a set as soon as I get mine back. Right now my 3011 is at the dealer. Last trip out the A/C kept freezing up and was blowing chunks of ice. They replaced the unit yesterday as it was losing freon. I have had a problem since day one putting air in the right inside dual and they are supposed to address that as well as replace a frig fan that has a bearing noise. Would like to get everything done before we head up to BamaGanza. Ooops sorry, i did not mean to hijack the thread
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 11-01-2015, 12:04 PM   #28
hammer55's Avatar
Phoenix USA AML1 Air Inflation Kit; on amazon
has anyone put these on, they attach to the lug nuts,
http://www.amazon.com/Phoenix-USA-AM...t%3B+on+amazon
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 11-01-2015, 12:25 PM   #29
Commercial Member
I use extenders by Wheel Master 8208 as that way I don't have to mess with lug nut torque if/when I get involved with TPMS issues.
What ever you use be sure the outer end if firmly tired down.
I use pop rivets with the small angle brackets provided in the kit.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 11-01-2015, 12:27 PM   #30
Commercial Member
Thanks Boso. Now to figure out what to do about the outer "J" extension. Borg Tire Supply has permanent ones for $20 each, but as I mentioned before, it required me to trim the wheel simulator that I used on my E-350. But then I had a non flexible inner extension that may have been the problem. My local tire dealer can easily install this by just breaking the bead and swapping out valves then rebalance. Probably about $25 a tire. Still that's about $100 for just the those installed.
The bottom photo shows what I had to do on the E-350. Notice the trimming. But the E-450 does have the bigger 4" holes instead of the 2".
This type of extender is OK as long as you remember to hold the valve body when you press on it to add air or check inflation. The force needed may eventually cause damage to the rubber grommet.
tire, valve
