Old 10-28-2015, 10:35 AM   #1
e450 or e350
Hello,
I pretty much decided on a 2016 forester 2301 but have the option of either the 350 or 450 engine. There's a $3,000 difference in price. I don't plan on towing a vehicle so I initially thought the 350 would be fine. However given the same weight I'm thinking the 450 would experience less wear over time. Moreover I do plan on driving in some mountainous regions so I would think the 450 would perform better.
I would appreciate any thoughts on this.
Thanks in advance.
John
JZales is offline   Reply With Quote
Old 10-28-2015, 10:44 AM   #2
gasman94's Avatar
If it were me, I would opt for the 450. Besides motor, I believe that it has a heavier suspension which should increase your carrying and towing capacity. Also, when going through mountains/higher elevations, gas engines lose power as you increase elevation so if the 450 has the v10 with more horsepower, this is another reason to upgrade.
Rich
gasman94 is offline   Reply With Quote
Old 10-28-2015, 11:13 AM   #3
E450
X2
Kevin & Judy is offline   Reply With Quote
Old 10-28-2015, 01:56 PM   #4
I have never heard anyone complain that they bought a unit that had too much power.
naysmitj is offline   Reply With Quote
Old 10-28-2015, 02:00 PM   #5
gasman94's Avatar
X2
Rich
Old 10-28-2015, 03:59 PM   #6
Total Loss's Avatar
450 will have a bigger rear end, suspension and possibly rear frame section.
Motor and trans should be the same.
Possibly a different rear end gear ratio also.
Go to Ford's commercial website- they should outline the differences.
Total Loss is offline   Reply With Quote
Old 10-28-2015, 07:04 PM   #7
gasman94's Avatar
Information here is a little dated, but I think it will give you an idea of what other rv'ers think
Good Sam Club Open Roads Forum: E-350 or E-450 Chassis for 24' Coach w/Slide
Rich
Old 10-28-2015, 07:46 PM   #8
Thanks all. It's unanimous for the e450. Rich, thanks for the link. A lot of good info there.
John
Old 10-29-2015, 10:11 AM   #9
I have a 450 on a 2701 Forrester and have never felt I had too much power, especially in the NC mountains where we live. If it struggles, the 350 would certainly have a hard time. I would opt for the 450 for sure.
elynnkelley is offline   Reply With Quote
Old 10-29-2015, 02:35 PM   #10
vwexpert's Avatar
The Ford cutaway page shows the V10 / 6 speed trans drive train option also for the E350 (same as E450). So it's basically how beefy a chassis you want / need.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
