Old 08-08-2015, 04:09 PM   #1
Citrus County, Fl.
GL1800Rider's Avatar
Entry Door Gas Shock Position
Can somebody tell me if the fat end part of the gas shock on the entry door is supposed to be attached to the coach frame or to the door? I think mine may be backwards as it seems to compress when the door is closing but the door flies open and seems to put a lot of stress on the mechanism. Mine has the fat part closest to the coach frame and the skinny rod attached to the door. I was going to reverse it and see what happens but thought I would ask here first.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-08-2015, 06:03 PM   #2
From a functionality point of view it doesn't matter. It will work either way. Don't have your specific model but my house has screen doors and they all have the cylinder (big part) attached to the door.
ATVer is offline   Reply With Quote
Old 08-08-2015, 08:58 PM   #3
papap's Avatar
Mine did not come with shock. Can you post picture of yours?
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-08-2015, 09:14 PM   #4
Citrus County, Fl.
I will post it up in the morning. Looks like it may be particular to 3011/3010 and maybe the smaller units with the door all the way to the front.
99 Terry 31G
Old 08-08-2015, 09:31 PM   #5
benagi's Avatar
I don't think they come on any of the 3170's or 3171's.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 08-08-2015, 10:23 PM   #6
papap's Avatar
Has anyone ever added one?
Old 08-09-2015, 12:34 PM   #7
halbright's Avatar
I have a 2106 Solera 24W. My door spring works the same way and I have the same concerns with the stress on the pins in the door and in the door sill. It doesn't matter which direction they are pointed. They work the same way. I just had to replace mine as it pushed the door out quickly and would then not allow it to close. It jammed in the fully extended position. The replacement works exactly the same as the original. It pushes the door open quickly rather than opening it gradually. Until we can find a replacement that will control the opening speed, we have to remember to hold on to the door while opening and to not let go of the door until it is fully opened. The gas spring holds the door in place while open.
halbright is offline   Reply With Quote
Old 08-09-2015, 12:59 PM   #8
Left Coast
Need to change mount on door ..play with position.
Old 08-09-2015, 02:01 PM   #9
Screen Door Adjust
Our house screen door is attached with the barrel end on the screen door. At the end of the barrel is an adjusting screw that controls the closing speed. You may want to see if you too have an adjusting screw that may help.
Peter is offline   Reply With Quote
Old 08-10-2015, 10:38 AM   #10
DKRITTER's Avatar
Mounting a shock upside down, right side up, left or right usually doesn't matter. Just look at it and do what makes the most sense.
DKRITTER is offline   Reply With Quote
door, gas
