Old 05-14-2018, 07:23 PM   #1
External Gaps / Cracks - Potential Leaks
I have a 2016 Forester 3051S with gaps / cracks near the driver's side rear corner. The first picture shows a gap just above the the rear horizontal molding just above the license plate. The second picture shows cracks where the corner molding is attached to outside edge of the rear cap. (don't know how to rotate the pic.) As you can see, we have full body paint on this motor home.
I am interested in hearing your thoughts on how I should make these repairs. I think that I have previously attempted to close the gap on the horizontal molding here and elsewhere with clear silicone caulking, although it has not proven to be a good long term repair. I have not yet attempted a repair to on the rear cap.
ID:	171858   Click image for larger version
dyeats is offline   Reply With Quote
Old 05-14-2018, 07:28 PM   #2
cavie's Avatar
Do not use silicone on the outside of your rig. It doesn't last long and nothing else will stick to it especially paint. Use non-silicone based caulking.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-14-2018, 07:30 PM   #3
sgtlm17's Avatar
I have the same cracks on my painted Forester. Struggling with same question. As stated silicone does not prove to be a long term repair. I am thinking colored exterior window caulk.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 05-14-2018, 07:40 PM   #4
cavie's Avatar
Check with your RV repair/supply house. I sure someone will jump in here soon. There are many different types. You can't use the Dicore self-leveling as it won't stay in place on a vertical surface..
Old 05-14-2018, 07:51 PM   #5
Duckogram's Avatar
I suggest you use one or more of these Dicor sealants. They are non-sag.
551LSB 10.3 oz. tube Black New!
551LSD 10.3 oz. tube Dove (Bright White)
551LSG 10.3 oz. tube Grey
551LST 10.3 oz. tube Tan
551LSV 10.3 oz. tube Ivory
551LSW 10.3 oz. tube White
ILB ( | )
Old 05-14-2018, 09:41 PM   #6
This sounds very promising. Are the colors that you mention matching colors to the Forester Full Body Paints?
Old 05-15-2018, 04:19 AM   #7
sgtlm17's Avatar
Colors will be close. Thay usually have a tan, dark brown, cream, etc
2011 Jeep JK Toad
Old 05-15-2018, 07:05 AM   #8
I'd either try Dicor No-Sag or some of this:
https://www.amazon.com/Geocel-28100V...QW1HNWN8BZXFVS
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 05-15-2018, 10:22 AM   #9
Wandering's Avatar
Saw it recommended in another thread and used Geocel Proflex on my Forester a year and half ago. Looks like new now. I used the clear so I have a couple minor spots where painted caulk peeled and color doesn’t match. You need to apply and smooth quickly. It sets up pretty quick and is a sticky mess. Found it on Amazon https://www.amazon.com/gp/aw/d/B001F...op_mb_pd_title
Forester 2451s
Wandering is online now   Reply With Quote
Old 05-15-2018, 09:52 PM   #10
X2.
Mask off the areas to be caulked so that you don't leave a mess.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 05-15-2018, 11:50 PM   #11
It sounds to me like the ProFlex RV Sealant will work well on the horizontal molding.
However, I'm concerned about the crack on the edge of the rear cap. It seems to me that the crack in the paint may be developing because the molding is separating from the cap.
If that is the case, is a sealant a repair technique, or just a band aid? How do I figure out what is really going on?
Old 05-16-2018, 08:26 AM   #12
Duckogram's Avatar
Take a lightweight box, bolt it to a truck chassis, then hurdle down our ultra smooth higways exposing the box to gale force winds. It’s going to cause seams to separate, screws to fall out, paint to crack and fiberglass to bend. Keep it sealed to prevent water from getting in. Water will destroy an RV from the inside out. It’s the nature of the beast.
ILB ( | )
Old 05-16-2018, 08:36 AM   #13
jeff64's Avatar
X2
If you need to smooth the Proflex out, wet your fingers first and keep dipping them in water. The only place I'd use silicone bathtub caulk is in a bath. Silicone is a bugger to remove and get a clean enough surface to put the right stuff on. ie. plastic scrapers, mineral spirits, rubbing alcohol and plenty of elbow grease!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
crack, leak
