Originally Posted by Bama Rambler
Assuming that you're going to use a regulator on the external tank and connect to the low pressure fitting on the RV, then as long as you have the correct regulator, there is no more plumbing to be done. It will work just like the onboard tank does.
True but one note. "External Connections" such as those for outside kitchen stove tops or BBQ's may not provide sufficient flow for a furnace. The Quick Disconnect fittings (assuming this is the external connection in question) only have to provide enough flow for a couple of burners (10,000 btu's max) and a BBW that consumes 10,000 btu's on average.
Furnaces can range from a low of 19-20 k btu's to well over 40,000 btu's.
Would be worthwhile to check the furnace requirements and flow rate for the fittings which often have small 1/4" orifices in them.
Not saying it couldn't work, just pointing out a potential issue if the furnace has a big appetite for "gas" while running.
Might be a good idea to consider tapping into the low pressure line and installing a 1/2" Quick Disconnect (with separate valve like most low pressure setups use) and use this larger line to feed the low pressure "main". Here's one from Amazon:
https://www.amazon.com/dp/B07BK3JBC1...xpY2s9dHJ1ZQ==
The 1/2' QD will flow a lot more low pressure gas than the usual 1/4" QD setups for outside kitchen or BBQ. At 88,000 BTU/HR you could run almost all propane appliances at the same time with no fear of starving the furnace while running.
BTW, this only works if you have a separate regulator on the external tank. Just wanted to make sure that was clear.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
