Old 03-18-2014, 05:42 AM   #21
Tinkerer and Putterer
Well hopefully I can close things out cleanly. It looks like I won't be able to get to the factory before my warranty runs out so I'll need to go to the dealer. If I have problems with the work or find water related damage that can be traced back to this leak after my warranty is out, will it still be covered since the original issue was submitted prior to my warranty expiring?
HappyGuy is offline   Reply With Quote
Old 03-18-2014, 09:14 AM   #22
GM
bclemens's Avatar
Just make sure you get it documented and you should be fine.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-23-2014, 08:02 AM   #23
I was surprised when I went up on the roof of our Sunseeker. Surprised to find the side rails covering a joint between the pebbled fiberglass roof and the plastic or fiberglass rolled side piece. I had assumed the roof was one piece rolling over the sides. Disappointing.
The rails are lightly caulked, the screws are not caulked, and the rails form a bathtub to catch water. As soon as I saw it, I knew I had an Eternabond tape job in my future. I plan to do it when the weather warms up. The good news is the light amount of caulking will make the tape application go more smoothly.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 03-29-2014, 05:35 AM   #24
Plain Old Member
The 2 biggest complaints I had about the design of this roof was 1, what Snowman mentioned. The roof held water after a rain, or from the AC condensation, which stayed there until it evaporated or you took off down the highway. 2, seemed like the cap (on top) was way higher than the roof level, requiring a LOT of sealant to close the gap. Seems like the cap could have had a more snug fit. Every one I've seen was like this.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
2012, led
