Old 01-22-2016, 10:54 PM   #1
filling propane tank
When filling propane tank on my class C, should the valve to the motorhome be turned off before filling the tank. I am quite often on this website enjoying all the knowledge to be had here. Thanking you in advance.
5hfarms is offline   Reply With Quote
Old 01-23-2016, 10:17 AM   #2
Yes. In fact the attendant who fills the tank will do that. Like filling up an automobile with gas, the rules require you to turn off the engine and close the valve to the tank.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 01-23-2016, 10:21 AM   #3
Yes, shut the supply valve off. Also shut the vehicle engine off. They are pumping the liquid propane in to the tank. The valve and regulator are made to use the propane as a vapor, and not as a liquid.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
propane, tank
