Old 10-10-2016, 02:57 PM   #1
Sagecoachdriver's Avatar
Foggy rear tail light
I recall seeing others here on the forum having them same isssue of the rear tail light filling with water. I had that happen and my dealer resealed the other edges of my tail light. Seemed to work. But when I washed the MH today, I the clear backup lens fogged up. Obviously, there is water penetrating into the tail light. I believe it must be entering from the backup lens cover. There are 2 screws holding the lens on. I have removed the lens and there is a very thin ring seal. It is very difficult to reseat the seal. Has anyone out there encountered this and di you use any silicone or other sealant?
Is this the same problem that has prompted the RECALL of other tail lights?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 10-10-2016, 04:01 PM   #2
Total Loss's Avatar
Taillight
I found it seeps in through the center clear lense.
You have the 2 screw unit- they will NOT seal good enough with the crappy foam seal.
Clear silicone around it and reinstall.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 10-10-2016, 05:10 PM   #3
waiter21's Avatar
DUH - You're OBVIOUSLY using the wrong kind of Blinker Fluid...
https://youtu.be/E6GsXhBb10k
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
light
