Old 08-16-2016, 03:30 PM   #11
SeaDog's Avatar
This is a good example of the reason for putting your 110V connections inside a junction box so if it does fry the box will contain it. Good luck with reimbursement, and let us know how it turns out.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 08-16-2016, 03:34 PM   #12
slipf18's Avatar
O yeah...
Originally Posted by B and B View Post
I am going to ask Bob Byrne to get involved. Leo is here at the Rally in Goshen from FR and I am sure they can resolve this.
...And while you're at it, tell him to try building their products with a bit more quality control and integrity... build quality and materials suck.
2017Winnebago 2500RL, Hobie Odyssey
Aspen 5.7L HEMI V8,Tekonsha P3
Blue Ox 1500 WDH Airlift 1000# bags
Barker 3500 Tongue Jack
DW & a feisty Border Terrier named Painter
slipf18 is offline   Reply With Quote
Old 08-16-2016, 03:48 PM   #13
Dazed & Confused
M&K Hoffman's Avatar
Originally Posted by Ej1332 View Post
I've never seen a ground burn up in 18 years of electric work unless there some other issue ( 12 volt DC circuits are a different story). I would have the circuit going to your ac checked again. Sound like to me that there is something messed up with the neutral(white)on that circuit and the ground is carrying the neutral load.
Got to agree here except add in my 40+ years of electrical work. Grounds should only carry current when a fault condition exists.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 08-16-2016, 05:41 PM   #14
mbbutler's Avatar
X2 ej1332
mbbutler is offline   Reply With Quote
Old 08-16-2016, 06:18 PM   #15
mike.t's Avatar
Companies have numbered invoices, estimate sheets and or quote sheets. So it wont show up at the end of the year as income (taxes) they use these at times. The work was done and the company pocketed the $ Not a big deal and Forest River knows this and will use it as a reason not to pay.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 08-16-2016, 07:44 PM   #16
VinceU's Avatar
Don't think the ground burned up. The picture shows the yellow lead, formally white had its wire nut melt away. To the tech the white and ground are synonymous, they aren't.
VinceU is online now   Reply With Quote
Old 08-19-2016, 04:57 AM   #17
DouglasReid's Avatar
Originally Posted by pribbens View Post
On the basis of the original issue , I opened up the connection box above the filter. Quick note, yes, I did turn off the circuit breaker and, did check to see if 115 volt was present with my non contact voltage sensor.
Once inside, white ground and black wires wrapped in black electrical tape. So the only way to inspect the connection is to remove the tape. when I was halfway through, I noticed that the black wire was coming out of the wire nut.
Now, was this do to me fiddling around with the wires? , possibly. However, I don't think I untwisted or did any untwisting of the other wire nuts or this one.
Anyhow, I didn't like the way that the stranded wire was wrapped around the black solid connector. I didn't like the exposed copper wire above the wire nut.. so I trimmed about an eighth of an inch of wire off the black conductor. I wrapped the stranded conductor around the solid black conductor. I applied the factory supplied wire nut. At first I thought it would be too small but it actually works rather well. Was able to get a good torque on the black wire nut. When I applied the same torque to the white and ground conductors I was able to get several turns on each wire nut.
I finished off by wrapping all three wire nuts with black tape. Primarily to prevent the wire nuts from coming loose. As there was no exposed copper showing now. I closed up the box remounted it cleaned the air filter, put on the cover. Turned on the circuit breaker.
I know this says nothing about how Forest River is handling the issue. However I am glad the poster mentioned this so that I could look at a potential problem, averted; down the road.
Now, if you want to be REALLY thorough do the same to each and every 120 Volt connection in every box in your RV.
If that one is loose, chances are there are more........The same workmen did all your connections.
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 08-19-2016, 09:22 AM   #18
psribbens
Yes, of course you're right. It's going to have to wait until I get to home base to dig into that level. Thanks for the reminder though.
Forester Ford E450
2017 3011DS
pribbens is offline   Reply With Quote
forest river, show
