02-26-2017, 09:53 AM
Forest River Suggestion
On my Forester the water heater is on the drivers side. ALL of the water users, sinks, & shower are on the passenger side. It would be VERY simple to swap installation location with the furnace.
Dave W AKA "Toyman"
Well modified Forester C 2551
Why ?...Why not ?
02-26-2017, 09:56 AM
Why do you care?
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
02-26-2017, 10:00 AM
Why would that be necessary?
Also note that the water heater may be where it is to distribute weight.
Also furnaces are placed for ease and efficiency of ductwork runs.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
02-26-2017, 10:07 AM
Originally Posted by RSchleder
Why do you care?
The OP likely cares so they wouldn't have to draw as much water before hot would arrive.
In a boondocking situation, conserving water is paramount. The amount of water down the drain before hot arrives can add up to gallons.
02-26-2017, 10:11 AM
I would think a simple trade off would be to insulate the hot water line, no duct work for furnace and no plumbing, minimum cost and less water wasted while waiting for hot water to arrive.
Retired Navy
2016 Flagstaff 26 FKWS
02-26-2017, 10:15 AM
And I alway thought there were no dumb questions !
There is already heat ducted to the drivers side.
Dave W AKA "Toyman"
Why ?...Why not ?
02-26-2017, 10:26 AM
I prefer furnace on passenger side so I don't hear it when outside since outside passenger side is where we sit. Not a deal breaker though. And yes my furnace is on the passenger side and water heater is on the drivers side.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
02-26-2017, 10:49 AM
Why would you run the furnace if you are sitting outside??
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
02-26-2017, 11:36 AM
what about the cold air return? moving a furnace requires reducing of both supply and return.
Retired Navy
02-26-2017, 12:15 PM
2012 Solera
When boondocking, I collect the pre-warm shower water. I use it for the dog's water. Also helps stretch the capacity of the gray water tank - the dog "transports" the water outside!
JLeising
2012 Solera "S"
Calif SF Bay Area
02-26-2017, 01:13 PM
We boondock more than 50% of the time and our WH is on the driver side immediately adjacent to the shower resulting in almost instantaneous hot water. Would it have been a deal breaker if the WH were located elsewhere? Of course not, but it is darn convenient. If the designers are starting with a clean slate why not locate the WH as close as you can to the faucets? Although I suspect my WH is where it is because that's where it would most easily fit.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
03-11-2017, 11:56 PM
I prefer anything hot, water heater and furnace, to be on drivers side. Why? Because both will have some very hot areas that little hands can come in contact with. Our last motorhome had the water heater right by the entrance door. I always worried about little ones touching it.
