Old 03-01-2012, 06:59 AM   #1
forester 2012 sunseeker 2650s
can anyone tell me a little about the air suspension bags in rear of rv. i have air values on both sides to inflate, if necessary, but can't find any literature as to what pound of air to use, when , etc.
redryder8 is offline   Reply With Quote
Old 03-01-2012, 10:30 AM   #2
GM
bclemens's Avatar
It is the "Firestone Ride Rite" spring assist system.
Min air pressure is 5, max is 100. I'm pretty sure we put them at 60lbs from the factory. It is going to be personal preference for the most part.
However if after loading your unit up, one side is leaning. You can pump that side up, while reducing pressure on the other side so that you balance the load.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 03-10-2012, 02:27 PM   #3
I had a set of instructions (same one the poster linked too) included with mine. I keep mine around 45-55 depending on load. They are very helpful and the ride is quite good for a RV!
mwebber78 is offline   Reply With Quote
Old 03-10-2012, 04:23 PM   #4
capndinghy's Avatar
Mine were set at 50psi by the dealer on Delivery. So far, so good.
capndinghy is offline   Reply With Quote
