Old 04-01-2016, 10:06 PM   #1
Keithe's Avatar
Send a message via AIM to Keithe Send a message via MSN to Keithe Send a message via Yahoo to Keithe
Forester 2401S Slide Question
I've read though this forum and I'm still having problems figuring out where the hex nut is to manually operate the slide on my 2017 Forester 2401S. Below is a photo of the slide motor with the hex nut circle which I believe is used to manual operate the slide. Can someone confirm that this is the correct hex nut?
Also, according to the manual they recommend disconnect power to the slide motor before manually operating the slide. Can this be done using the battery disconnect switch to turn off power to all the RV? This seem like it would be the easiest way to cut power to the slide motor.
Thanks,
Keith
Keithe is offline   Reply With Quote
Old 04-02-2016, 04:38 PM   #2
MNtraveler's Avatar
Schwintek recommends disconnecting the motor and manually pushing the slide in.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 04-02-2016, 07:37 PM   #3
Keithe's Avatar
I've seen these videos but they are for a different slide than what's installed on my RV. In the manual I got from Forest River, the say to use a wrench to manually operate the slide. All the information I've seen from Forest River and from the slide manufacture isn't very clear on how to tell what model slide you have and how to manually operate the slide. Maybe I just haven't come across the correct documentation.
2017 Forester MBS 2401S
Old 04-02-2016, 08:25 PM   #4
2012 Solera
You may have a Lippert "Flush Floor" electric slide-out, like the one in our Solera. If so, this video may be more applicable:
I believe the hex in your picture is the manual "wrench it in" point. Of note, it may be easier to take out the two bolts on either side of the motor gearbox in your picture (which connect the shafts that drive the gears on the racks) and simply push the slide-out in.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 04-02-2016, 09:03 PM   #5
Keithe's Avatar
JLeising, thanks for the suggestion. I just looked at mine again and it does look like removing the two bolts connecting the shafts to the gears would be the easiest way. Hopefully I'll never have to worry about doing this but I'd rather be prepared if a problems with the slide ever arises.
Old 04-02-2016, 10:41 PM   #6
2012 Solera
Your welcome. Probably obvious, but if you do disconnect the motor and push the slide-out in, you will need to either re-connect the motor or use some form of slide-out locks to keep it from going back out while driving. My Solera came with a couple of PVC pipe pieces for that purpose. The pipe segments fit between the top of the slide-out and the outer wall to hold the slide-out in.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 04-03-2016, 12:05 AM   #7
MNtraveler's Avatar
In one of the videos, the demonstrate "blocking it in" basically with a 2x4 cut to the right length.
Land of 10,000 Lakes
2016 Forester MBS 2401R
Old 04-03-2016, 07:26 PM   #8
psribbens
Off Topic, Slide stops 2401S
This past winter had the slide stops re-installed under warranty after one came loose and the other fell out fortunately, this was in our driveway, but for the duration of the fall trips we manually stopped moving out the slide. Don't know if additional length was added to the lag screws bonding the stops to the structure, as I have not deployed slide since getting it back from the dealer two weeks ago. Might be something you would periodically inspect, I know I will be doing it this season.
Forester Ford E450
2017 3011DS
pribbens is offline   Reply With Quote
Old 04-03-2016, 09:08 PM   #9
Slides are different on our 2014 - 2500 TS Schwintek slides are on the bed room and the wardrobe . On the dinette its normal lippert slide. and can be manually moved in or out with a socket connection which is in the compartment right below the dinette slide.
Brandon 2
2500 TS
brandon 2 is offline   Reply With Quote
Old 04-09-2016, 07:31 AM   #10
Wolverine 1945's Avatar
I think our Sunseeker 2500TS has 2 different slides ???
I only know where the Hex nut is on the Dinning room slide !!!
Same as Brandon !!!
Wolverine 1945 is offline   Reply With Quote
forester, slide
