Old 02-27-2016, 10:07 AM   #21
How much CCC (cargo carrying capacity) does a late model 3011/3010 have? Thanks.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 02-27-2016, 01:57 PM   #22
Tinkerer and Putterer
The CCC varies on the options on the rig but it is plenty for our family of 4. I did have an issue with the nose getting light when I had the 4 bikes on the back and no toad. Moving some of the things we pack in to the cab over bed fixed that problem. I have been through the Appalachian mountains many times and the rig can hold 60 mph running between 3500 and 4000 rpms. Much above 4000 the gas mileage really dives because you get out of the torque peak above 4200 rpm. I lose 5 mph going up grade with the toad staying at the same rpm range. If you lose momentum going up the grade forget about getting it back but the rig will hold speed going up grade quite well.
HappyGuy is offline   Reply With Quote
Old 02-28-2016, 07:51 PM   #23
Citrus County, Fl.
GL1800Rider's Avatar
Ours has everything except the power seat and the ccc is 1610
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 02-29-2016, 08:51 AM   #24
Class C Representative
Joshua Cavitt's Avatar
The 3010 has around 2100LBs of CCC.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
forester
