Old 09-17-2016, 06:29 PM   #11
Forester 3011DS air suspension
Here we go- a few pics of my install.
Plugged the hole on the passenger side
Could have gone shorter on the air hoses, cleaned things up a bit, but I wanted to make sure I had enough to work with.
Used the included fuse tap to pull power from the converter.
vajeep is offline   Reply With Quote
Old 09-17-2016, 06:33 PM   #12
DaGrinch's Avatar
SWEET!
On the Amazon Wish List of "things to get over the winter".
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 09-20-2016, 03:31 AM   #13
Thanks for the post. My new Ď17 3011ds won't hold air for 10 minutes on the right side.
Azzy1016 is offline   Reply With Quote
Old 09-20-2016, 07:16 AM   #14
VinceU's Avatar
That condition will wear out the air pump in short order, better to use soap suds on the fittings to locate the leaks first.
Old 09-21-2016, 08:23 AM   #15
Chief tinkerer
Gidyupgo's Avatar
Grinch, we gotta' do this. Great setup Jeep. Any trouble routing the line across to the passenger side and did you need to adapt the fittings? Did you reroute and connect to the existing hose on the pax side or connect the new line to the top of the bag, removing the old line?
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-21-2016, 07:01 PM   #16
DaGrinch's Avatar
Yeah, Buddy! Good questions, Gidyup!
I've got one more outing this year. DW told me to make my "List of things to get done for NEXT year".... THIS is on the top!
Old 09-22-2016, 07:19 AM   #17
Now here is an interesting question. Is there anyway to use this same compressor to fill air in the tires? If so, then it might be worth looking at as then I would not need two compressors. (one dedicated to the air bags and one portable for the tires)
newRVer is offline   Reply With Quote
Old 09-22-2016, 07:33 AM   #18
Chief tinkerer
Gidyupgo's Avatar
NewRV, the OP can weigh in, but my thoughts are, it takes a pretty beefy 12v compressor to do tires in a timely manner, but yes you could. If you go to a 110v cmprssr to get the volume for tires, you can't do the bag quick adjust at the pump.
Gary
Old 09-22-2016, 01:17 PM   #19
Tombsy's Avatar
They have a system with a 2 gallon tank and an auxiliary air line for tires and toys.
https://www.airliftcompany.com/produ...ems/quickshot/
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is offline   Reply With Quote
Old 09-23-2016, 04:16 PM   #20
Routing turned out to be a piece of cake. The lines are both routed along the frame rails at that point- once you pull the line out of the passenger side, yank it across to the driver's side. Used a couple zip ties to keep it neat. I used an extra push 't' fitting and simply cut the valve off, cut the driver's line, and pushed them together. If you are careful of the wire loom you'll keep it all wrapped and factory looking pretty easily.
forester, suspension
