09-08-2016, 07:48 PM
Forester 3011DS air suspension
Anyone install an on-board compressor to keep the air bags full? It stinks having to check and fill before every trip, and then every few days after that on a long drive.
Would be nice to just have it be automatic.
09-09-2016, 09:58 AM
The "Wireless air 72000" works great. It keeps a constant set air pressure in the bags and you can adjust the pressure while driving.
Jim
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
09-09-2016, 10:44 AM
DW's 401(k) Plan
Jim
Any pictures of the installed set-up and how you routed lines?
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
09-12-2016, 08:48 AM
Jim
awesome, thanks!
is this the one?
https://www.airliftcompany.com/shop/72000/
09-12-2016, 06:45 PM
I just use a bicycle pump with a gauge.
Takes less than a minute per side.
Tom & Alice
2013 Sunseeker 2860DS
2005 Honda Cr-v Toad
2004 Jayco 31BHS (stored in Myrtle Beach)
09-12-2016, 10:47 PM
Yes...that is the system
I believe Amazon has a good price on it
09-14-2016, 08:40 PM
I went with the cheapest of the AirLift units -
AIR LIFT 25804 Air Shock Controller Kit https://www.amazon.com/dp/B000CFO05E..._cSF2xbTCB32VD
Mounted in the wet bay, where the left side fill was. Pulled power off of the converter (which is also in the bay) and routed the right side line across & used a 'T' to connect it in with the other. I've lost the ability to fill them independently, but frankly don't care. The analog gauge and controls are right there in the bay, easy to check and run every time I stop for gas.
Turned out to be a quick and inexpensive fix to an annoying task. Now I don't have to unpack the bays to check air, or run around to both sides, or dig out a pump and stow it when I'm done. I'll try to remember to snap a pic in daylight tomorrow.
09-14-2016, 08:46 PM
DW's 401(k) Plan
Originally Posted by vajeep
....I'll try to remember to snap a pic in daylight tomorrow.
09-15-2016, 10:38 AM
awesome, thanks for that.
can't wait for the pics.
09-17-2016, 07:22 AM
I have the ''RIDE RITE SYSTEM'' on my Class C motor home...do you think it would work on mine. That system looks great. Thanks .
09-17-2016, 06:29 PM
Here we go- a few pics of my install.
Plugged the hole on the passenger side
Could have gone shorter on the air hoses, cleaned things up a bit, but I wanted to make sure I had enough to work with.
Used the included fuse tap to pull power from the converter.
09-17-2016, 06:33 PM
DW's 401(k) Plan
SWEET!
On the Amazon Wish List of "things to get over the winter".
09-20-2016, 03:31 AM
Thanks for the post. My new ‘17 3011ds won't hold air for 10 minutes on the right side.
09-20-2016, 07:16 AM
That condition will wear out the air pump in short order, better to use soap suds on the fittings to locate the leaks first.
09-21-2016, 08:23 AM
Chief tinkerer
Grinch, we gotta' do this. Great setup Jeep. Any trouble routing the line across to the passenger side and did you need to adapt the fittings? Did you reroute and connect to the existing hose on the pax side or connect the new line to the top of the bag, removing the old line?
Gary
2017 SunSeeker 3010DS
09-21-2016, 07:01 PM
DW's 401(k) Plan
Yeah, Buddy! Good questions, Gidyup!
I've got one more outing this year. DW told me to make my "List of things to get done for NEXT year".... THIS is on the top!
09-22-2016, 07:19 AM
Now here is an interesting question. Is there anyway to use this same compressor to fill air in the tires? If so, then it might be worth looking at as then I would not need two compressors. (one dedicated to the air bags and one portable for the tires)
09-22-2016, 07:33 AM
Chief tinkerer
NewRV, the OP can weigh in, but my thoughts are, it takes a pretty beefy 12v compressor to do tires in a timely manner, but yes you could. If you go to a 110v cmprssr to get the volume for tires, you can't do the bag quick adjust at the pump.
Gary
09-22-2016, 01:17 PM
They have a system with a 2 gallon tank and an auxiliary air line for tires and toys.
https://www.airliftcompany.com/produ...ems/quickshot/
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
09-23-2016, 04:16 PM
Routing turned out to be a piece of cake. The lines are both routed along the frame rails at that point- once you pull the line out of the passenger side, yank it across to the driver's side. Used a couple zip ties to keep it neat. I used an extra push 't' fitting and simply cut the valve off, cut the driver's line, and pushed them together. If you are careful of the wire loom you'll keep it all wrapped and factory looking pretty easily.
