Old 05-22-2016, 09:09 AM   #1
Forester 3051 Big Foot Levelers questions
I have used the search feature and just can't find the right answer. We just picked up our 2016 Forester 3051. We have had it two nights. We got the levelers down the first night, had to put some wood under the tires so they didn't come off the ground. Its in our driveway which is pretty level but slightly sloped to the rear for water drainage. We took a ride yesterday, came home and thought we leveled it. Woke up this morning and realized that none of the stablizers were down. We tried to do the automatic and the back two come down and then nothing with the front two. The green light in the center is on and then left and right are flashing. Our bubble level is pretty close, off maybe a quarter inch. Any suggestions? Are the fronts supposed to come down even if its level without them? I can't find anything in the little tiny brochure they gave us. So overwhelmed right now.
gandb26 is offline   Reply With Quote
Old 05-22-2016, 03:33 PM   #2
sgtlm17's Avatar
Yes fronts should come down whether level or not. First let's see if the fronts are working. Make sure emergency brake for vehicle is on. Keys removed from ignition. Bigfoot also recommends the coach be plugged into shore power or Genny running since it is a large power draw on the batteries. Turn Bigfoot system on at control board. Press the manual button till light illuminates. Press the front jack buttons to see if they are getting power and will extend down in manual mode. Once you can confirm they operate then you can move forward with diagnosing problem.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 05-22-2016, 04:31 PM   #3
Ok. Took it somewhere else more level and fronts came down but not the rears. Back in the driveway, lowered everything, all 4 came down and then the rear tires were off the ground so we retracted everything and drove up on boards and then I have a flashing rear and solid right light. I can not for the life of me figure out what the issue is. But it sure is frustrating. Click image for larger version
Name:	ImageUploadedByForest River Forums1463952421.293393.jpg
ID:	108651obviously it's a picture so it doesn't show the flashing rear light. The rear tires were coming off the ground so we retracted everything and drove up on boards. Now again only the rears are down and I have flashing green foot and left and right. So without the boards, all 4 came down but rear tires off the ground. Put the boards under the rears and now only two came down and the green foot is flashing and right and left. Any ideas?
Old 05-22-2016, 04:43 PM   #4
sgtlm17's Avatar
Ok the lights that blink around the green foot show you that area is low. Example if the light on left front is flashing it is low. . The green foot in center with no lights shows unit is level. . HOWEVER I don't know if your unit is calibrated to level. . It is an easy process but first if your getting a light blinking left and right your control board needs to be reset. I don't know your rig layout but I can get to the back of the control panel through a drawer if you can great if not just remove 4 screws on front to remove control panel from wall. When you access the back there is only one plug. . Remove it for at least 1 minute then plug back in. . This resets the board. . You should no longer get the left and right lights blinking together. . Several causes require board to be reset but most common is a weak battery.
And I just noticed were neighbors.
Old 05-22-2016, 05:00 PM   #5
sgtlm17's Avatar
Send me your email via PM I have the Bigfoot manual in pdf form I will email it to you.
Old 05-22-2016, 10:08 PM   #6
KJcachers's Avatar
Never lift your rear tires off the ground. Your fronts could roll you right off the jacks and damage them.
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 05-23-2016, 12:15 AM   #7
Creativepart's Avatar
If your driveway requires your rear wheels to be off the ground when leveled (mine does) just turn your RV around, let your front wheels go as high as necessary. Just be sure to chock the back wheels and set your parking brake first. No problem.
My front wheels are probably 18" off the ground when level in my driveway..
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 05-23-2016, 01:44 PM   #8
I have a portable Big Foot controller on my Concord. Had similiar problem, called BF. They had me unplug from power box under driver seat, plug back in 10 min, let it reset. That solved the problem. Yours is fixed, so maybe pull fuse or breaker and see if it resets.
billcoll is offline   Reply With Quote
Old 05-23-2016, 01:48 PM   #9
gandb26, I had the same problem as you. I followed sgtlm17's instructions and reset the unit. I was not able to access through the panel under the fridge. I took it right out the front. It was very easy. I got it level. My one front is still off the ground, but I got it chocked. Jill
13STL is offline   Reply With Quote
Old 05-23-2016, 09:15 PM   #10
Not sure if we are leveling properly. We understood from walk through that we shouldn't have any wheels in the air. Still use leveling blocks with our Bigfoot levelers. Is this overkill? Just use levelers for fine tuning to zero degrees salesman said levelers shouldn't be used alone to have front wheels suspend in space. We're we misinformed?
suscamper is offline   Reply With Quote
305, forester
