Old 10-05-2014, 10:14 AM   #1
West Cactus's Avatar
Forester 3051 water leak
We are on the road and have what I think is fresh water leaking near one of the leveling jacks. Any ideas what it might be? We are on the road after picking it up so no time for dealer for a few more days!
Name:	ImageUploadedByForest River Forums1412522061.586008.jpg
2015 Forester 3051S
West Cactus is offline   Reply With Quote
Old 10-05-2014, 10:21 AM   #2
That is the drain cap for hot water just reach under and tighten it up by hand I have same rig as you
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 10-05-2014, 10:34 AM   #3
Next stop, tighten it will be! Many thanks. How do you like yours? Ours is 3 days from the seller and we are lovin it!
2015 Forester 3051S
Old 10-05-2014, 10:50 AM   #4
West cactus After getting few items repaired after pickup from dealer we love the unit. One thing to watch is the screws on the outside wall bracket where the slide is, mine had the bottom five screws strip out ( another member on this forum had the same thing happen also)was easy fix just put in bigger screws Enjoy yours , we are!!!
2014 Forester 3051s
2012 Sonic toad
Old 10-05-2014, 03:51 PM   #5
Does the blue drain hose also require a drain cap? I filled the fresh water tank the last time I was camping and the water leaked out after I filled it? Had to get another site with city water hook up.
coldj is offline   Reply With Quote
Old 10-05-2014, 03:58 PM   #6
No the blue hose doesn't have a cap, if water is leaking out it, check inside the storage cabinet on right side of MH ( second from rear) there is a compartment inside this cabinet where the water pump, water filter and cold water drain shut-off is. Check that the drain is shut off ( its a little silver quarter turn valve)should be at 90 degrees to the blue pipe its in.
2014 Forester 3051s
2012 Sonic toad
Old 10-05-2014, 03:59 PM   #7
jimdd810's Avatar
That blue hose is probably the over flow for your fresh water tank
Life is a highway!!!!!
jimdd810 is offline   Reply With Quote
Old 10-05-2014, 04:25 PM   #8
Average Joe
MrJoe's Avatar
Yep... It's this.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
305, forester, leak, water, water leak
