Old 10-05-2013, 03:00 PM   #1
ricfr's Avatar
forester 3121ds water heater
where is the water heater located? I've looked everywhere. The only vents are for the fridge and furnace.
ricfr is offline   Reply With Quote
Old 10-05-2013, 04:46 PM   #2
bikendan's Avatar
go outside and you should be able to find the outside hatch to the WH. it'll have vents on it.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-05-2013, 04:50 PM   #3
Ford Idaho's Avatar
Mine is next to the refrigerator both are behind the same cover, yours might be sharing a vent cover with something.
Old 10-05-2013, 04:51 PM   #4
TURBS's Avatar
This is what you should be looking for.
Old 10-05-2013, 04:52 PM   #5
TURBS's Avatar
The little black switch turns on the electrical heating element if its a suburban wh.
Old 10-05-2013, 05:24 PM   #6
wmtire's Avatar
If you look at the 1:58 mark of this video, you see the white water heater panel right underneath the words "Forester by Forest River" on the passenger side. It's just a few inches below the words.
It's like the hatch Turbo pointed out.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-05-2013, 05:34 PM   #7
TURBS's Avatar
Yep there it is!
Right above the furnace outlet.
Old 10-06-2013, 01:52 AM   #8
ricfr's Avatar
3121ds water heater
thanks everyone I appreciate your help.I found the water heater panel (suburban)and the water heater itself is hidden under the sink counter. Had to take out teh drawers to see it. Now i just need to figure out how to drain it and bypass it I dont see any bypass under the counter. just the red and blue lines.
Old 10-06-2013, 05:15 AM   #9
wmtire's Avatar
To drain it, you'll pull the anode rod out...which you access from the outside of the RV.
These links may help, and show you where the anode rod is. You will need a 1 and 1/16 inch socket to pull the anode rod.
http://www.forestriverforums.com/for...ore-36197.html
Drain the hot water heater?
Anode facts and FAQs
Before draining, it's a good idea to make sure the water is cool (not heated), and you may want to open the pressure relief valve (shown in pic) to let the water flow out better. You don't want to stand in front of the water heater, as the water will come out very quickly.
Old 10-06-2013, 08:24 AM   #10
TURBS's Avatar
Nothing like this?
forester, heater, water, water heater
