Old 10-29-2016, 10:37 AM   #1
rcman1953's Avatar
Forester GTS 2431s drain locations
This is for those who haven't found the drains. I just took delivery of a 2017 Forester GTS 2431s. The fresh water tank drain is behind the round white screw off cover on the other side of the bed. Not a real convenient place. The low point drains are located just to the left of the entrance door. You can see them thru the propane door. The winterizing lines are behind the square panel in front of the shower and the handle is for that also. Hope this helps others who may have been looking.
2016 Keystone Hideout
2016 Forester 2801QS
2017 Forester 2251SLE
2017 Forester GTS 2431S
Arkansas
rcman1953 is offline   Reply With Quote
Old 11-02-2016, 09:45 AM   #2
I have not drained mine yet. There was a panel in the aft-most righthand side compartment that said low point drain as well. You might want to check that out as well. Hope that helps.
kranki is offline   Reply With Quote
cat, drain, forester, location
