Old 03-15-2015, 06:50 PM   #1
Forester tv playback options?
Do all of the tv's have a coax that allows Over the air, and do all of them have a HDMI input?
carlb is offline   Reply With Quote
Old 03-16-2015, 11:03 AM   #2
Actually do they all have an HDMI input?
Brian?
Old 03-16-2015, 01:33 PM   #3
GM
bclemens's Avatar
All TV's have an HDMI input. All TV's will have coax for over the air channels.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-16-2015, 01:35 PM   #4
GM
bclemens's Avatar
To clarify, there is not a central HDMI hub that feeds everything. We have no idea what a customer will set up. Each will have a coax cable so you can watch HD TV over the local channels. What you do after that is up to you, but they can all take input from an HDMI source.
Old 03-16-2015, 06:18 PM   #5
I have a friend who is into home automation and I am investigating options for AV in the RV.
Most of the deployment scenarios require an ethernet cable to each TV that then goes into an adapter which converts the signal to HDMI. Not sure what the costs are but don't want to carry a ton of BlueRay Disks or DVDs for the minions to watch while rolling down the road. My friend mentioned the system would likely be based around the RTI or URC controller platforms.
Will share more details as I get them.
forester
