Old 10-12-2016, 11:54 PM   #1
wvufan1958's Avatar
(Forestor 2861 DS ..w/ Arctic Package.. Also with Heatpump.)
Can anyone please tell me what is the coldest temperatures you have ever been in using ...the Arctic Package ? Thanks
wvufan1958 is offline   Reply With Quote
Old 10-13-2016, 01:26 PM   #2
sgtlm17's Avatar
I can't speak for artic package yet since I haven't done cold weather camping yet. However I find anything lower than 45 degrees outside I prefer to go to the furnace in lieu of the heat pump.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 10-14-2016, 08:35 AM   #3
I have a sunseeker with the arctic package and have used it while driving down to about 10 degrees with no issues. Never really used the tank heaters when parked since if it's cold enough to worry about freezing, I'll have the furnace on which heats the basement.
As for the heat pump, I've used mine successfully down to 30. Even through, it's really not supposed to work well in temps that low, mine will. Now, the propane furnace heats much faster and feels warmer below about 40. One thing to remember is the heat pump does not send any heat to the tanks and wet bay. Only the propane furnace does that.
jrwalkerpa1 is offline   Reply With Quote
pump
