Originally Posted by lexstone
I do have two lines, hot and cold. Opened both and opened the sink faucet which drained some of the fresh water tank but not all as the wall monitor indicated there was still a full tank of fresh water. The fresh water indicator probably is faulty and the water drain line is not hooked up properly? I looked at your pics again and my water pump is different. It is more towards the bottom of the coach.
The low point drains do not drain the fresh water (FW) tank. They only empty the hot (red) and cold (blue) water pipes in the coach. There should be a separate valve under the coach to drain the FW tank. As you've already discovered, you also need to drain the filter housing separately.
You'll also want to drain the water heater if the coach will be sitting unused for a while. I drain mine if I'm not using it for more than 2 weeks, others leave it longer.
