Old 04-28-2019, 02:49 PM   #1
Fresh water flow rate (City Water)
Anybody had low water flow rates with their Forester. I am using an inline filter and a Camco Water Pressure restrictor. Iím am using a 25í 1/2Ē fre sh water hose.
I am thinking that I should switch to a 5/8Ē hose as the first step.
Any opinions would be great.
v/r rch
RHOUSER is offline   Reply With Quote
Old 04-28-2019, 02:58 PM   #2
nomad297's Avatar
Toss the Camco restrictor. It has nothing to do with the size of your hose.
Bruce
nomad297 is online now   Reply With Quote
Old 04-28-2019, 03:04 PM   #3
ejohnson1144's Avatar
Clean your airators on your faucets they may be plugged
ejohnson1144 is offline   Reply With Quote
Old 04-29-2019, 07:30 AM   #4
Removed the pressure restrictor and allís well. I have a Camco elbow as well that probably restricts the flow as well but does relieve the stress at the hose to city water connection.
Thankís for all the help. v/r. rch
Old 04-29-2019, 07:36 AM   #5
Trailer Park Supervisor
NJKris's Avatar
Doubt it's the hose I.D., as I believe most of the trailer plumbing is 0.5" I.D.
NJKris is offline   Reply With Quote
Old 04-29-2019, 07:49 AM   #6
ben31's Avatar
I would get one of these: https://smile.amazon.com/gp/product/B01N7JZTYX
It is an adjustable regulator, not just a restrictor. This will allow you to adjust the pressure to what you need.
If you travel around, you may run into too much water pressure. Admittedly, it doesn't happen often, but if it does, your in for a world of problems. Therefore, I wouldn't feel safe with just attaching the hose with nothing in between. This will give you as much pressure as you want (up to the limit of the actual feed), without worrying about getting too much.
I, too, used to always complain about the lack of pressure. Once I got this, it improved dramatically. I set it at 50psi. The suggested limit for my RV is 60psi.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 04-29-2019, 10:06 AM   #7
Does this happen at every campsite? If so, follow the above suggestions.
We've come across campsites where there is low water pressure and they advise you not to use a water pressure regulator. Also, some campsites have permanent pressure regulators installed at each campsite.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 04-29-2019, 10:16 AM   #8
Those are not pressure regulators.
They are vacuum breakers/backflow preventers.
They are required by code in some places.
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 04-29-2019, 10:20 AM   #9
Nope. That's not it. They look like the pressure regulator we use. We've seen the backflow preventers and we then install our pressure regulator.
Happy Camping!
Old 04-29-2019, 10:21 AM   #10
Denver To Yuma In 90 Days
It seems that most people like to cheap out on the flow restrictor and buy the $15 cheapie from Walmart or Camping World, which I believe is a 40-50 PSI restrictor.
Spend the extra $10 (still at Walmart or Camping World) and get the better 50-60 PSI restrictor and that will work good, or go big and spend around $80 for the adjustable regulator.
JohnD10 is offline   Reply With Quote
city water, fresh water, water, water flow
