Old 10-05-2016, 09:21 AM   #1
fresh water tank drain???
Hi folks I have a 2251 SLE 2015, Going to do my winterizing, got under the motorhome and could not see a drain , valve or pet cock on the fresh water tank. Any body help on this, Thanks
model71 is offline   Reply With Quote
Old 10-05-2016, 09:35 AM   #2
SeaDog's Avatar
The drain may not be under the rig but in your basement storage compartment thats were mine were on my class A. let use know where you find them
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-05-2016, 09:59 AM   #3
Check around the propane tank. I have heard this is where it may be located.
Old 10-05-2016, 12:36 PM   #4
ilmor's Avatar
On my 2250 it is found in the outside rear storage compartment. Inside the compartment is one of those round white plastic access panels. Unscrew the opening and I find the valve inside next to the water tank.
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
ilmor is offline   Reply With Quote
Old 10-05-2016, 04:02 PM   #5
ilmor, Thanks for the pointer, Drivers side back bin, inside the inspection port was a valve , I opened the valve and water ran out at my feet.Thanks for the help,much appreciated.
Old 10-11-2016, 05:33 AM   #6
ToniandSal's Avatar
I have been wondering about that too. I think it would be a good idea to drain our fresh water tank because it's been fairly hot here lately. I don't want to take chances with the water going bad.
2016 Forester 2291S Class C
2016 Jeep Wrangler
ToniandSal is offline   Reply With Quote
drain, fresh water, tank, water, water tank
