Old 12-24-2015, 08:18 PM   #1
Fridge not closing
3051 double door fridge does not close tight. We also need to bungie it closed to travel. Am I missing something? Just started this trip.
Cheers
naysmitj is offline   Reply With Quote
Old 12-24-2015, 09:01 PM   #2
Boso's Avatar
Adjustment on hinges I believe or it has a warranty I think for three years if you have it serviced every year if not you void the warranty that's the kicker
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 12-25-2015, 04:16 PM   #3
KJcachers's Avatar
Mine won't catch properly either. Haven't looked at the hinges. I feel the latch on the door is not "springing" back far enough to catch the latch on the frame. Just the right hand door. The left works fine.
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 12-25-2015, 06:33 PM   #4
Yes, that is the same issue. Right door does not latch properly.
Old 12-25-2015, 08:56 PM   #5
KJcachers's Avatar
I'll try and take a look at that issue tomorrow. See if there is something simple I can adjust. If not it goes back to the dealer with a list of small things I want taken care of that should have been done before delivery. If it ever stops raining I need to get on my roof and check everything again while installing 3 Maxx Air vent covers
Jason and Karen
2015 Forester 3051S
Old 12-25-2015, 09:20 PM   #6
Batts-toy's Avatar
Take a small mallet (or hammer) and tap the catch on the frame it is probably not seated fully in, I had this issue on my Wildwood and also a while back helped a person on this forum correct the same issue.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 12-26-2015, 12:54 PM   #7
Citrus County, Fl.
GL1800Rider's Avatar
I had mine at the dealer for 3 weeks for a new A/C unit. When I left the house I turned off the fridge and put the adapter on to keep the doors from closing. When I picked it up the doors would not latch so they ordered new ones which have not been put on.
We left the next day for a 1000 mile round trip and the vacuum from the fridge being on corrected the issue. Dealer said there is a known issue with the handles not latching on the 4 door one.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 12-26-2015, 01:33 PM   #8
KJcachers's Avatar
Is there a generic door lock for these that would slide in between the handles forcing them to latch while traveling? I'm thinking a simple plastic, wood or even a cardboard shim will force the handles to latch properly.
Jason and Karen
2015 Forester 3051S
Old 12-27-2015, 06:49 AM   #9
Citrus County, Fl.
A ball point pen works.
99 Terry 31G
Old 12-27-2015, 03:11 PM   #10
KJcachers's Avatar
Fridge not closing
Here is what I was able to do to get mine to latch. I will also keep a shim between the handles when traveling, just to make sure things stay latched while in motion. Btw, my freezer doors were both fine. Just that right fridge door had issues.
http://youtu.be/pqgPEtsXCIY
Jason and Karen
2015 Forester 3051S
fridge
