Old 12-21-2015, 12:14 AM   #1
Creativepart's Avatar
From the Roof to the Basement
Yesterday I was on the roof installing a SAT Dish. Today, it was in the basement installing a Thetford Sani-Com system.
It was super easy - found 20 Amp power source nearby (the converter is right next door and had an unused 12-v connection that's always hot) and the unit just twisted on to the dump pipe.
This photo doesn't show much but it's there. On the left is the Sani-Con hose and sever connection. The Sani-Con pump in the middle looks square but that's just the control box sitting on tip the round pump. The hose on the right is for the black tank flush.
I'm anxious to try this out. Seems like it will simplify the entire process.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 12-21-2015, 01:18 AM   #2
Sagecoachdriver's Avatar
Creativepart, why the Sani-con, are you using it at home to dump?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 12-21-2015, 01:01 PM   #3
Yes, we plan to dump through our sewer clean out at home. But also, because it's easier and cleaner.
Old 12-21-2015, 01:19 PM   #4
I used a Sewer Solution kit for years to dump using a cleanout I installed at the house. About 30 feet and up about 2 feet. Worked great because we have high water pressure. When we had our sewer line to the street redone, I had a 4" cleanout place right at the sidewalk where I can now just run a 20 foot 3" RV sewer hose to it. Actually, I have full hookup here with a 30 amp dedicated panel and water spigot.
Old 12-21-2015, 01:49 PM   #5
Boso's Avatar
I could never see any benefits except pumping up hill I have seen them in action can't see it being any cleaner but slower
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 12-21-2015, 01:51 PM   #6
Much slower and wastes a lot of water. Not good here in California!
Old 12-22-2015, 12:59 AM   #7
I did a lot of research of the Sani-Con. I found a lot of people that had one and loved it. And many that never owned one but thought it a bad idea.
Ever noticed that all expensive coaches come with them standard? I doubt that's because they don't work well.
I've used the traditional dump hose for 15-years and now I'm going to find out for myself.
I'm talking about the Sani-Con not the Sewer Solution. Water is not an issue.
Old 12-22-2015, 01:06 AM   #8
I know they work well and I even considered getting one but my old Winnebago had too small an area to hook it up. I suppose I could have made a short 3' hose with fittings and lay it on the ground. But that was when I was a young newbie. Now I am an old newbie
Old 12-22-2015, 11:26 AM   #9
vwexpert's Avatar
I had a sani-con in my Diplomat. It's cool...but not sure it's better. My only issue was it took a long time to empty the tanks.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 12-22-2015, 12:27 PM   #10
Left Coast
If it's a slow dump, just gives you more time to git!!
Old 12-22-2015, 03:40 PM   #11
Boso's Avatar
If it is now on all the upper end coaches means they have added something else to charge you 5 to 10 times what it cost them that's just business not a upgrade best to add it like you did if you can't live without
Old 12-27-2015, 02:17 PM   #12
I bought the sani-con to use both at home and our cottage at the lake. We have no plumbing options out there. Just an outhouse. I can use the sani-con to pump into the outhouse. And not have to drive out to a park to dump. We also have no electricity so the solar panels are very helpful. We are essentially boondocking there all summer. Also installed a stay a while? propane adapter so I can augment from a 30 lb tank and fill it as necessary. Flawless execution. Very happy with the unit and our year of travel. 27,000 km of smiling along the road!
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
roo, roof
